04-09-2016, 03:53 PM | #1 |
#3 1968 c20 cst
First 2x4.
Stock 327 TH350 It's all there but one piece of molding. If you can spot it and you got it, I want it haha. With keeping the stock intake manifold on how much horsepower can I get outa this motor with a rebuild? What should be done to the rear end to make this a street toy? It has HD springs. Thanks!
Paul "Mike" Tzareff |
04-09-2016, 05:44 PM | #2 |
Scrapper 1
Re: #3 1968 c20 cst
Boy this is a striped down modal the only 2 options i see are the AT and the 327 and side molding.reminds me of my 1967 Chevy camaro all it had was a 3 speed on the floor factory with the 327.Later i was told the car is more rare then the yenko's cus every one used them for crash up car's drag car's and beaters.
I do have some good new's for you i don't a lot of leg work on the 3/4 tons of that year if yours has leaf spring rear end you can do a swap with just front spindles to 1/2 ton for 300.00 and find a 1971-87 1/2 ton that has leaf spring and you have a 1/2 ton truck with disc brakes Check with CCP.com they make front end parts they make spindles that will take your 3/4 ton ball joint and tie rod all you need to buy is backing plate caliber rotor porshtiing valve disc brake brake hoses and you have a good nice usable 1/2 ton truck |
04-09-2016, 06:30 PM | #3 |
Junior Member
Re: #3 1968 c20 cst
I seen that on craigslist out there. Nice little rig!!!
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
04-09-2016, 06:38 PM | #4 |
Re: #3 1968 c20 cst
Nice truck. Probably has a pretty deep rearend - since you mentioned it as a street toy, and the original trans is already long gone (TH350 never came in a 68), you could swap in an o/d trans as the most bang for the buck to get more 1st gear torque multi and much, much better highway rpm. Much more efficient than just a rear gear swap, kills two birds with one stone. That kinda cool don't come cheap though. Personally, I think that ol gal would prefer to be freshened up or restored and used as a truck!
04-09-2016, 07:15 PM | #5 |
Re: #3 1968 c20 cst
You know what transmission came in the 68?
I think this is an Eaton axle. I don't expect it to be a drag truck, but I like it to burn some rubber and get off lights. It a 2x4 so it's gonna live on the street. ( I have two 4x4s). I just want to get as much HP out of a motor rebuild while keeping it pretty stock and build the transmission to handle it. And maybe a position rear end.
04-09-2016, 07:27 PM | #6 |
Re: #3 1968 c20 cst
Realistically about 300HP would be my guess IF its built right, the rear end is a GM 12 bolt probably, could have 3.07 or 3.42 to 1 ratio, i think that ratio was dependent on if it was a standard or auto tranny stock. If it was mine I'd not hesitate to do a rebuild.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-09-2016, 07:36 PM | #7 |
Re: #3 1968 c20 cst
Stock trans, if automatic, would have been a TH400. Guessing(!) stock rear would likely have been more like an Eaton HO with 4.10 (but not sure with an automatic... don't have my gouge stash handy )
04-09-2016, 07:39 PM | #8 |
The Niner
Re: #3 1968 c20 cst
That right there is my dream truck - a 68 C/20
Please leave it a 3/4 ton. Please, please, please.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
04-09-2016, 07:40 PM | #9 |
Re: #3 1968 c20 cst
Sweet!!!
04-09-2016, 07:42 PM | #10 | |
Re: #3 1968 c20 cst
They make a kit 8lug rotors and drop spindles with new heavy duty steering.
04-09-2016, 07:43 PM | #11 |
Re: #3 1968 c20 cst
I thought you were already driving your dream truck!! It's sure my dream truck!
04-09-2016, 07:48 PM | #12 |
The Niner
Re: #3 1968 c20 cst
I like the 67-68 noses better.
04-09-2016, 07:48 PM | #13 |
The Niner
Re: #3 1968 c20 cst
Thank you.
04-09-2016, 07:54 PM | #14 |
Re: #3 1968 c20 cst
Ya, know, they are kinda growing on me too... I've wanted to track down this one for AGES (yes, this exact one! Last seen in Prescott Valley...): 68 K20 CST Custom Camper. But I digress, sorry to hijack (!), I was getting all excited... This is a 2x4 THREAD!!!!
Btw Paul, what are your two 4x4s? |
04-09-2016, 08:01 PM | #15 |
The Niner
Re: #3 1968 c20 cst
Sorry, more thread hijack!
http://www.ebay.com/itm/Chevrolet-Ot...m=152044686212
04-09-2016, 08:06 PM | #16 |
Re: #3 1968 c20 cst
oh I've been watching that there bad boy.... Little too rich for my blood. I prefer to buy them in rough shape, sink a fortune in them, then sell them later for less than the original purchase price.
04-09-2016, 08:09 PM | #17 | |
Re: #3 1968 c20 cst
68 GMC K2500 w utility bed.
04-09-2016, 10:23 PM | #18 |
Re: #3 1968 c20 cst
nice combo
04-10-2016, 03:06 AM | #19 | |
Re: #3 1968 c20 cst
04-10-2016, 08:02 AM | #20 |
Re: #3 1968 c20 cst
Cool truck , my 67 327 4 barrel three speed truck had 220 hp stock , had it rebuilt I wanted a little more hp and be reliable so 300 hp was good for me. Not much motor work, it needed a bore so it got a 30 over with a very mild cam using same Rochester carb rebuilt also and using stock exhaust manifolds with a stock type dual exhaust. I think 327 could come up to 350-375 hp from the factory, also being reliable but with different heads and intake things like that. Can't wait till its all back in and driving around.
Nick |
04-10-2016, 07:16 PM | #21 | |
Re: #3 1968 c20 cst
I'll probably follow a similar route. 300 should be fun. I want to keep the heads and manifold on it.
04-11-2016, 09:54 AM | #22 |
Re: #3 1968 c20 cst
Was going to be my comment also , I thought all c20s had turbo 400s if they were autos , 327 is a great engine
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
04-11-2016, 12:17 PM | #23 | |
Re: #3 1968 c20 cst
If not, I think that is the only couple of pieces of 67/68' molding that I have off these trucks..lol. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
04-11-2016, 12:56 PM | #24 |
Re: #3 1968 c20 cst
Nice truck, funny--I need the same molding piece!
04-11-2016, 02:38 PM | #25 |
Re: #3 1968 c20 cst
[QUOTE=Coley;7556706]....did you get your molding piece? (passenger side...back of cab, correct?)
If not, I think that is the only couple of pieces of 67/68' molding that I have off these trucks..lol. All Good Coley[/QU I haven't found an original yet, just a repop. If you've got a piece you'd be willing to part with, ID be willing to pay a fair price. It's literally the only thing I can find missing. Even the original buddy buckets the guy is gonna sell me, for extra haha
