Old 04-09-2016, 04:08 PM   #1
ibrown50
ibrown50's Avatar
64 Panhard Bar Question
My 64 C10 has an axle from a later truck (I think 65).
Apart from a 64 Pb being too long, the frame bracket is also at the wong angle so simply fitting a 65 PB is not a good solution. The previous owner had fitted a 65 bar and bent one end to make it fit.
You can see from the picture how much the PB misses the bracket by.
My plan was to make a new bracket fitted further back on the frame and shorten the bar, however, I now plan to make a new bracket and mount it on the "outer" side of the frame, (and not shorten the PB) this will give me the longest possible bar.
Does anyone know why I shouldn't do this????
Any advice appreciated
Ian
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 04-09-2016, 06:02 PM   #2
62chevy302
hillbilly
62chevy302's Avatar
Re: 64 Panhard Bar Question
Here is a thread that deals with the same thing,although most of these deal with the relocated bar that bolts to the other side trailing arm mount. I am not sure why its too long though.
http://http://67-72chevytrucks.com/v...d.php?t=661523
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 04-09-2016, 06:10 PM   #3
62chevy302
hillbilly
62chevy302's Avatar
Check out post 8
http://http://67-72chevytrucks.com/v....php?p=7281226
-1962 C-10
Old 04-09-2016, 10:21 PM   #4
vince1
I took a pic of the 66 frame bracket today but can't get it to send to my email so I can't get it to the desktop so I can't post it here. Will try again tomorrow. If someone else can post a picture of a 65 or 66 bracket, feel free.
I had the same problem when I had a 64 diff in my truck for a while and had to stress the bar to get it to line up. Going the other way trying to line up a short bar to a 64 would probably be worse.
vince1 is offline   Reply With Quote
Old 04-10-2016, 12:01 AM   #5
Slow Build
Slow Build's Avatar
Top 64, bottom 65.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-10-2016, 12:57 PM   #6
Ken Magura
I have the same problem on my 64. I located a junk rear end from a 64 and i'm thinking about cutting the axle bracket off the 64 rear and welding it on my 65 axle that is in it now.
I think this may be a good solution to the problem.
What do you think?
Ken
Ken Magura is offline   Reply With Quote
