Old 04-09-2016, 04:29 PM   #1
68Timber
I know the pieces fit
68Timber's Avatar
Windshield gasket adhesive removal?
I've got the glass out and my old seal off but there's a ton of sealant to remove. What's the right way to get this stuff off? Scrape or wire wheel or ? I've got a little rust in each bottom corner that needs some rust converter on it but I don't want to go all the way to metal on the rest of it if I don't have to - this is a rattle-can repair on my military Blazer.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-09-2016, 07:57 PM   #2
Oberon67
Re: Windshield gasket adhesive removal?
In your place I would try a scraper and very judicious use of a heat gun... but that might be a bad idea.
Oberon67 is offline   Reply With Quote
Old 04-09-2016, 11:14 PM   #3
68Timber
68Timber's Avatar
Why?
John
74 Honda Z50 build
Old 04-10-2016, 06:15 AM   #4
Oberon67
Why?
It depends on what's close to the area you want to heat, that isn't heat-tolerant. If you're not careful you could melt a hole in the dash pad that way.
But the heat itself would be helpful in removing the sealant, of that I am certain.
Old 04-10-2016, 10:06 PM   #5
68Timber
68Timber's Avatar
The dash is out, so I tried the heat gun. That worked pretty well, thank you sir.
I have two rust holes I need to weld some patches in. Anyone know what gauge steel is in the windshield channel? I have some front inner fenders in the scrap pile I could use to cut some patches out of, but they're thinner steel aren't they?
John
74 Honda Z50 build
