Old 04-09-2016, 06:24 PM   #1
FLYNAVY30
8 AN fuel pick up w/ 6 AN return for stock tank??
Im converting my 6.0L LS swap from a carb over to a Holley Terminator EFI set up. Im going to run and external Holley pump but am having a hard time finding an 8-AN feed/6-AN return that will fit the stock tank in my '72 C20 Suburban....any help/input would be greatly appreciated. Thanks!!
FLYNAVY30 is offline   Reply With Quote
Old 04-09-2016, 06:52 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 8 AN fuel pick up w/ 6 AN return for stock tank??
which part are you looking for? The AN sizes are the 1/2 and 3/8's respectively. You can adapt to and from an existing hardline with a hardline (tube) to AN adapter fitting.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-09-2016, 08:10 PM   #3
FLYNAVY30
yea, the problem is that the factory hard lines coming out of the factory pick up are much smaller. Im looking for an aftermarket pick up that actually has an 8-AN pick up and 6-AN return, all the way down to the tank.....Mallory used to sell one but nobody carries it anymore.....
http://www.summitracing.com/parts/maa-4205
If I can't get anything to work, I may consider a replacement sump style tank with bungs in the sump for an 8-AN pressure line and 6-AN return....although Id rather not spend the money if I can avoid it.
Old 04-09-2016, 10:16 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
From sending unit to pump on mine I just used reg 3/8" gas hose, after the pump is where I started with my -an fittings and steel braid hose. I used the vette filter reg and just hooked the bypass back to the tank with 5/16" gas hose.all my stuff is under the bed and outta sight so visually nobody sees it .really not much need for steel braid on suction side of pump. And I've had no issues on the return either
