S10 frame swap questions
I know this is a heavily addresses topic on here, but I've gotten down to the frame this afternoon, cut off the appropriate body mounts and now I'm staring at the frame horns. How much do you normally cut off? Anything else I need to do before building my mounts?
Posted via Mobile Device |
Re: S10 frame swap questions
There is not a magic number but just to get it close to the steering box as poss. Then duplicate for pass side.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
I'm buying a 1950 .5 window I want to do s-10 frame swap just found out its a 3 quarter ton will that matter body should be same correct
![]() Join Date: May 2007
cab and fenders are the same, usually the bed on a 3/4 ton is a long bed so you will need to shorten it about 10 inches if you are using a longbed s10 frame.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
