Old 04-09-2016, 10:25 PM   #1
Nodnarb76
Nodnarb76's Avatar
3/4 ton Suburban 1 ton suspension swap?
After my motor swap is done, going to start replacing suspension stuff.
When I replace the rear leafs, thinking of going with the 3500lb rated springs.
If I wanted to swap the front coils with one ton springs, wouldn't I need to replace the control arms as well? Would the truck sit level with this setup?
Would the one ton control arms bolt up to my 3/4 ton frame?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
