Old 04-09-2016, 10:27 PM   #1
custom10nut
custom10nut's Avatar
Removing trim from back of cab and tailgate
What does it take to get the stainless trim from the back of the cab loose, without breaking or bending anything? Also the thin aluminum trim on the tailgate? Does it require any special tools/hooks to release either one?
custom10nut is offline   Reply With Quote
Old 04-09-2016, 11:24 PM   #2
El Dorado Jim
Re: Removing trim from back of cab and tailgate
I would like to know also....
El Dorado Jim is offline   Reply With Quote
Old 04-10-2016, 12:49 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Bookmarked.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-10-2016, 12:51 AM   #4
68bowtie
68bowtie's Avatar
for the tailgate trim, the outer ends have nuts behind that need to be removed. the rest of the long trim pieces have normal push-in trim clips. the handle has barrel nuts that push in. you simply go behind them with a thin flat tool and pry the trim pieces off. carefully obviously. there may be plastic tools designed for this, i'm just not aware of them.
the cab paint divider trim slides over small plastic clips which slide over the studs on the cab. start on the ends (closest to the doors) by carefully reaching behind the trim and sliding the plastic clips off the studs. once you get the 2 or 3 clips removed from near the cab corner, you can slide the whole trim piece off at once.
Old 04-11-2016, 12:48 AM   #5
El Dorado Jim
thanks for the info.
