Old 04-09-2016, 11:25 PM   #1
wesmigletz
wesmigletz's Avatar
HD Rear end recommendation for a 1967 C10 w/Coil Springs
I have a 67 C10 with a 12 bolt rear and coil spring suspension. I want a stronger rear end for regular driving duties, and some 11 second 1/4 mile passes. I prefer a bolt-in rear end, but will consider having one built.
What would be a good source for a donor rear end? Are there any bolt-in Dana 60s? What about modifying a late model rear end to work? In addition to having the coil spring brackets welded on, would they need to be narrowed, too?
A shop recommendation in the North Dallas area would be appreciated.
Thanks in advance.
Wes
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 04-09-2016, 11:35 PM   #2
Mrturner1
Re: HD Rear end recommendation for a 1967 C10 w/Coil Springs
Sub'd, getting ready to do this as well.
Mrturner1 is offline   Reply With Quote
Old 04-09-2016, 11:56 PM   #3
The Chainsaw
The Chainsaw's Avatar
A set of axles and C-clip eliminators in your 12 bolt is plenty.
My uncle has a 72 swb with a sbc and nitrous. Runs bottom 11's on stock axles with just the C-clip eliminators.
The Chainsaw is offline   Reply With Quote
Old 04-10-2016, 12:43 AM   #4
68bowtie
68bowtie's Avatar
mid to late 70's big ford cars (t-birds, etc) came with disc brake 9" rears with 5'x5" bolt pattern. the mating surface width is pretty close to the c10's.
Old 04-10-2016, 01:08 AM   #5
SS Tim
SS Tim's Avatar
Actually Chevy installed 6 lug 3.54:1 Dana 60 rear ends in 68-70 C10 trucks with 396 engines and either suspension. They can also be found in 67-70 GMC C1500 and K1500 in a selection of ratios.
SS Tim is offline   Reply With Quote
Old 04-10-2016, 06:43 AM   #6
Redline novdog
Redline novdog's Avatar
I would be more worried about the driveshaft holding up than the 12 bolt. If the ring and pinion and bearings are ok , Run it!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 04-10-2016, 07:27 AM   #7
Is your truck 5 or 6-lug? While GMC used the 6-lug semi-floating Dana60 in some 1500s of ths era, try finding one. And finding a coil spring one will be many times more difficult. 88-up Z71 and light duty 2500s used a 14-bolt semi-floater that might make a good swap. You can have a Dana60 5-lug custom built. I want to do a Dana60 in my '67 project, but probably way down the line after it is on the road. I am fine with high strength shafts and c-clip eliminators till then. If you do break one, then is the time to build something stronger. That may never happen. Part of running the 1/4 mile is breaking stuff as you get faster.
Old 04-10-2016, 01:14 PM   #8
wesmigletz
wesmigletz's Avatar
Thanks for all the responses. I'm expecting to put 500+ HP to the wheels, with a blown 6.2L engine with cam and heads, and am worried about the stock rear end. I'd hate to destroy a nice factory 12 bolt posi that could be sold or traded. I figure that I'm going to have to have a drive shaft built.
A bolt in 6 lug Dana 60 would be great if I can find one. I don't think I could put a Ford 9" rear in my truck. I got a 9.3 inch Pontiac posi, that I had built for my old 57 Chevy, but at 60", I think it's too narrow. I'm going to have to have a drive shaft built.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 04-10-2016, 01:16 PM   #9
wesmigletz
wesmigletz's Avatar
Tim, thank you for sharing these charts, they will definitely help with my search.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
Old 04-10-2016, 01:19 PM   #10
wesmigletz
wesmigletz's Avatar
Yeah, I always manage to find the next weak link, but never do it at a good place or time. I also figure, that out of the current vehicles I own, I have the best chance of keeping the truck in a straight line and in one piece with the power the engine will be making.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
