New Brake caliper sticking
I replaced drivers side caliper as it was grabbing. New one does the same thing and the truck pulls to the right (passenger side) under hard braking. Any ideas?
Re: New Brake caliper sticking
Rubber hoses between frame and caliper are bad probably.
As nnstring said . The hose inside will collapse and hold presser . Best to go ahead and change both . The other is probably not far behind .
Sounds good I will give that a try. Thanks
That was the problem. Brake line has collapsed and was holding pressure. Thanks for the help guys!
