Could a bad ignition switch cause this problem?
I'm using this video as a sample of what my truck is doing. I've tried to shim the starter but it still gets hung up on the fly wheel or just spins. Starter is new on a chevy 350. You can jump ahead to the 2:45 time on the video. I've had to do the rush to battery dance as well.
Thanks https://youtu.be/hXjYF5otyXk |
![]() Join Date: Apr 2007
Re: Could a bad ignition switch cause this problem?
I won't say it can't be the switch but I doubt it. More likely the starter or the solinoid is junk. More likely the solinoid. Just because it's new doesn't mean it can't be bad. If it's new from the store exchange it and see what happens. that what I would put my money on.
![]() Join Date: Nov 2013
the only way that the switch could cause it.........if it's sticking in the start position or is shorted in the connector....I've seen them with melted connectors
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
![]() Join Date: Sep 2000
that is the starter Bendix slipping
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
Do you have the correct knurled shoulder bolts and a starter brace?
What ignition? Is it points or hei? |
Starter/solenoid or flexplate or the mating of the two.
Did you have the engine out? Is it possible you put the flexplate on backwards? That'd be your worst case. I've seen it before.
#7 | |
![]() ![]() ![]() Last edited by 66clow; 04-10-2016 at 01:43 PM. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Disconnect the purple wire from your starter and the yellow wire if you still have it on the starter.
connect a starter jumper between the large cable on the solenoid and the small S wire terminal. Disable the ignition coil or distributor so it can't start the engine. Now press the jumper button on the starter jumper and engage the starter. This eliminates the problems from everything but the starter and the solenoid. Timing,. poor conductivity on the S wire, bad ignition switch, etc. If you still get the problems then your starter solenoid is weak or shimmed incorrectly. Refer to my thread. http://67-72chevytrucks.com/vboard/s...d.php?t=655903
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#9 | |
![]() Quote:
![]() Join Date: Feb 2009
Seems these guys are on the right track. Did you shim the starter? If you ask me, it needs to be closer. If it grinds then it's too close. My guess is it's the solenoid, but I would remove a shim first.
On a side note, if that were my Corvette there would be a lot more padding on those fenders.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#11 | |
#13 |
Exactly. I did the same thing once and rec'd a lecture from a mechanic. Hard-line only, and if you choose an auxiliary filter it best be steel raised off the engine. I just use the filter at the carb. It's cleaner and works as intended.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-10-2016 at 02:40 PM. |
#14 |
Yes, thanks it is on the works. Did it to get it running but not road ready.
#15 |
Well to give you an update it was the ignition switch that went bad. The starter also didn't need any shims. Glad I didn't buy another starter. Thanks again for the help. After getting the new switch it seemed to turn and return easier than the old. Think it was getting hung up.
#16 |
I had a 77 chevy c1500 with a 350 I bought with the starter and flywheel that wouldn't mesh right, made an awful sound when starting, but started. I was getting the lifetime starter and flywheels from a chain store, three starters and flywheels later all with in a year, I just kept taking them back. So I took the final new in the box lifetime starter to my favorite salvage yard and told the guy, I would trade him even up for an old starter off a junk truck. Once installed I never had a problem again. The lifetime starters I could never get to work without the awful chirping noise......and eating flywheels.......
#17 | |
#18 |
Hmmm..........anything is possible on these old trucks.....
#19 |
![]() Join Date: May 2013
The correct spacing between the starter gear and flexplate is when an end of a paperclip wire will fit between the gears when they are engaged
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#20 | |
#21 |
#22 |
Msgt USAF Ret
Glad you figured it out and thanks for the feedback.
#23 |
Defiantly didn't see that being it. Would have bet the farm on bad solinoid or bendix. Like 71Chevyshortbed402 said thanks for the update. I hate when you follow a thread to see what really happened and you never find out. It's like when your favorite show ends the season in a cliffhanger and the show gets cancelled before the next season.
#24 |
I'm fairly green though I've replaced a few starters. How do you know when they're engaged without starting the ignition?
#25 | |
