Old 04-10-2016, 12:26 PM   #1
Pontiac1976
Pontiac1976's Avatar
Looking for hose emissions Decal pic's
Information:
Engine I have C10,1984 305 5.0L 4BBL. None A/c, No Air pump, Ps, Pb, Reg. HEI Dist.
Transmission I have TH350 1977 REG CAB Fleetside
Federal,(Canada north east) or the Altitude(200 to 600) version of Federal emissions
Decal sticker on the pass side Rad support w/color hose routing on right side + tune up spec on the left side sticker.
Rad support was bent toss out by a friend for scrap steel. I for got to get pic for later time when needed.
Any all info and Pic's of there motor at water neck too would be great
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-10-2016, 04:52 PM   #2
Pontiac1976
Re: Looking for hose emissions Decal pic's
Any one have 8F emissions code on there sticker what ID:# is that sticker.?
Old 04-15-2016, 10:24 PM   #3
Pontiac1976
bump any info???
Old 04-25-2016, 10:54 AM   #4
Pontiac1976
DOES any one have full pic of this style sticker info part #'s. other stickers like the air cleaner 80-84
