Old 04-10-2016, 05:46 PM   #1
davepl
davepl's Avatar
Behold! Weep at the beauty of my 4L80E linkage
I say that because I didn't make it... the guy installing my transmission did (and he's been on this thing all week, not looking forward to the bill).
The black plate is new; the dark grey bracket is unchanged, though it might be run upside down; the light silver bracket has been modified with the area that holds the rod being extended.
The rod comes within about 1/4" of the cab in park, but moves out as you go through the gears.
It winds up being almost perfectly aligned with the 4-speed OD gear indicator too, which is nice.
Lots of changes considering the 4L80E is descended from the TH400 (which was even renamed the 3L80):
- Driveshaft shortened
- New shift linkage
- TCU box under dash, bracket fabbed, programmed
- SCU box under dash, bracket fabbed, dip switches all set
- TPS box under floor, calibrated to carb
- crossmember relocated backwards to new location
- Parking brake cable relocated
Lots of labor, and as we all know, I'm cheap. But it's quality work, likely better than I could have done myself, and I never mind paying for stuff that's done better than I would do it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-10-2016, 09:11 PM   #2
john@thepier
john@thepier's Avatar
Re: Behold! Weep at the beauty of my 4L80E linkage
My guess from the looks of the linkage is your keeping it column shifted? How would something like a Lokar shifter coming up through the hump area have worked? That is how I have been envisioning doing mine when I get to that part of the build. Nice work by the way. Keep it up.
john@thepier is offline   Reply With Quote
Old 04-11-2016, 05:27 AM   #3
Heavymetl
Nice piece! Lol at the thread title.
Btw, I just used the Lokar shift rod for my 4l80e install.
http://m.summitracing.com/parts/lok-aca-1800
Me caveman build truck.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 04-11-2016, 11:34 AM   #4
davepl
davepl's Avatar
A shift cable would have been WAY easier, so you're all set.
I sent him the link to the a rod just like the Lokar unit, but wanted to stay stock appearing if possible, left him with the choice.
