Old 04-10-2016, 06:06 PM   #1
davepl
davepl's Avatar
ARP ultratorque lube? Sealant?
The LS flywheel bolts are spec'd at 75 ft lbs. Now comes the adventure.
They also are exposed to oil pressure, so you need sealant. So I got a new set of GM bolts and used ARP thread sealant, which has the same lubricating value as their thread lube.
As I was torquing the last one, it went. I hope it was the bolt and not the hole, I'm not 100% sure yet. Hoping the bolt stretched.
So I bought ARP bolts, and they say 85 ft lbs. They come with ARP thread lubricant, but not a sealant.
Should I use the ARP thread sealant that I have from their head bolts? I do NOT want a leak onto my clutch.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
