Old 04-10-2016, 06:19 PM   #1
fleetimus
fleetimus's Avatar
454
I am putting a 454 in my 68 C10. Long or short water pump?
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 04-10-2016, 06:27 PM   #2
hugger6933
Re: 454
Short will look more correct. But if that dont matter run whatcha got as far as brackets and whatnot. Now you may have to scootch back a hole so everything clears what kinda fan are you planning?
hugger6933 is offline   Reply With Quote
Old 04-10-2016, 06:27 PM   #3
SS Tim
SS Tim's Avatar
Re: 454
That depends on how you position the engine and if you use the factory 396 mounts. But all factory 396-402s in 68-72 were short water pump installations.
SS Tim is offline   Reply With Quote
Old 04-10-2016, 06:39 PM   #4
Mike C
Mike C's Avatar
Re: 454
Long mounts usually put the alternator on the passenger side. Would require rewiring. I'm building a 427 for my '69 and will be buying Hi-Perf passenger car deep groove pulleys for short pump for mine.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
