Old 04-10-2016, 09:58 PM   #1
bL.A.zer90045
96 vortec 305 mechanical fuel pump???
will a 96 vortec 305 block/engine have the provission to put a mechanical fuel pump on it?im wanting to carb it is the reason i ask?
bL.A.zer90045 is offline   Reply With Quote
Old 04-11-2016, 10:14 AM   #2
OutlawDrifter
Re: 96 vortec 305 mechanical fuel pump???
no
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 04-11-2016, 12:13 PM   #3
bL.A.zer90045
thanks for the confirmationso would my best bet be to run a carter elec pump??? anyone have a part number on ones they have run?
Old 04-11-2016, 12:19 PM   #4
OutlawDrifter
The carters work well, but are pretty noisy. Sorry no part numbers. Why not just run the factory pump and a regulator plumbed back into the return line?
1991 Z/28, 6.0L/T56
Old 04-11-2016, 12:35 PM   #5
bL.A.zer90045
so i could use the factory in-tank pump with a regulator on the rail?? this is for a 95 s10 with a 4.3 tbi.
Old 04-11-2016, 01:09 PM   #6
Tom
driving is in my blood
Tom's Avatar
Yes. Run the factory fuel line to a regulator, then the reg to the carb. Also run a return line back to tank from reg for excess fuel. Nice and simple.
Old 04-11-2016, 01:59 PM   #7
bL.A.zer90045
Appreciate the help guys!!! Any suggestions./ Recomandations on a regulator?
Old 04-11-2016, 07:53 PM   #8
speedygonzales
speedygonzales's Avatar
Contact Summit for a recommendation and give them all the information of the system. When you place the order for parts, put that person's name on the form when do and if it doesn't work out, you can return it with no hassle.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 04-11-2016, 09:03 PM   #9
bL.A.zer90045
ahhh the wise have spoken ill put it on my SCUMmit list
