Old 04-11-2016, 12:38 AM   #1
Sepulvd
Floorboard question
I have fixed minor rust spots before but am trying to figure out or ideas how I can fix this. I am decent welder. It's a 70 custom c10. I wouldnt have a problem if it was just in the middle of the floorboard but since it also affects the door frame am not sure. Thanks
Sepulvd is offline   Reply With Quote
Old 04-11-2016, 04:13 AM   #2
Franks 72
Franks 72's Avatar
Re: Floorboard question
Looks like you will be into a partial floor pan replacement / inner sil extension and rocker.What does the cab support under the floor look like? This photo is of a suburban but the concept is the same. If the cab support is gone you can purchase replacement pieces which can be welded in. All of the sheet metal parts can be purchased , just measure carefully before you cut. I did my suburban with the frame off and on a rotissary which made it a lot easier to work on. Good luck !
Franks 72 is offline   Reply With Quote
Old 04-11-2016, 12:54 PM   #3
Sepulvd
the cab supports look pretty good actually. Gonna have to research the parts and see if it's worth it
Old 04-11-2016, 01:48 PM   #4
Sepulvd
Looking at lmc for the parts am thinking its #3 and #6
