04-11-2016, 07:50 PM | #1 |
Identify Bushing on Clutch Pivot Bracket
Hope this is the right forum for this question. I am in the middle of having an engine project done (307), and the mechanic is not sure how/where to get a particular bushing. Can anyone make a suggestion -- is such a part still made, or is there some substitute that would do the trick? (See photos.) Thank you.
"Here is the clutch pivot bracket on your motor, I believe there is a nylon bushing that clips on it. The Z-bar slides over it to run the clutch. It is loose with out nylon bushing. The frame side is good, it is the motor side I am concerned with." |
04-11-2016, 08:08 PM | #2 |
Re: Identify Bushing on Clutch Pivot Bracket
Bushing
http://www.classicparts.com/1963-81-.../#.Vww8BfkrLIU Clip for holding bushing into z bar http://www.classicparts.com/1963-84-.../#.Vww8DPkrLIU Felt for frame end of Z bar http://www.classicparts.com/1963-74-.../#.Vww8F_krLIU About 9 bucks for all three items. |
04-11-2016, 08:12 PM | #3 |
Got my replacement bushings from The Truck Shop, but I'm sure any of the aftermarket vendors will have them. There is also a felt "seal" that goes on the end to keep excess grease from splooging onto the engine block.
04-11-2016, 09:35 PM | #4 |
Perfect -- thank you very much!
