Old 04-11-2016, 09:33 PM   #1
marbles34
Brake Light Issue
Hey All,
I have an 80 Chevy 2WD Stepside that the left brake light and left rear blinker doesn't work. The left front blinker works, the right front blinker works, the right rear blinker and running light all work. The only time the left rear brake light/blinker works is when the right blinker is turned on. Is this a possible issue in the blinker switch in the steering column?
Thanks in advance!
Chris
marbles34 is offline   Reply With Quote
Old 04-11-2016, 11:09 PM   #2
wbort27
Re: Brake Light Issue
ground in taillight housing to body my 75 did same thing same side hope it helps
wbort27 is offline   Reply With Quote
Old 04-12-2016, 01:05 PM   #3
willem445
willem445's Avatar
Check all your grounds before anything.
willem445 is offline   Reply With Quote
