What the ?*@#
... so I get ready to bolt on my water pump pulley / spacer / fan on my 250. Can't get bolts to start, so end up pulling radiator back out. Found holes on water pump snout drilled wrong, all holes 1/2 hole off ! Oh happy days ! Going to re drill and continue on I guess ...
If you don't like this ![]() |
Never Ending Projects
Re: What the ?*@#
GM has used 2 different bolt diameter patterns, that I have seen. Some water pumps have both patterns and others don't. I know on my Nova wagon, when I replaced the water pump, it had the correct holes for the factory pulley and fan. If you have a parts store local, you might see if they have a different pump that has the right pattern.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
