![]() Join Date: Mar 2016
Choosing a power steering gearbox.. to go high end or not?
I am looking for a new gearbox for my 69... the frame seems to be clearanced for the power steering unit... I was looking at a redhead or the AGR performance boxes but they are about 450$... how are people getting along with the A1 cardone rebuilds ? I am not about cutting corners nor am i about throwing an extra 350$ out the window on a power steering box.... I am using a gm type 2 pump with the Billet Specialties Tru-trac serpentine kit that I have it flows 3 Gallons per minute at 1200 psi... this should be more than enough to power the stock steering gear correct? any advice and experiences appreciated.
thanks |
Re: Choosing a power steering gearbox.. to go high end or not?
I installed an AGR variable ratio box and pump about a year ago. Best upgrade I've made in terms of driving enjoyment. Good road feel. Solid steering.
Figure out what you want--then figure out what you are willing to give up to get it. |
![]() Join Date: Jun 2014
I just ordered a CPP 14:1 quick ratio 500 series box. $380
I'll let you know how I like it, installing this coming Sunday probably. I'll be going from manual to power steering....no matter what I put on there it will be a big difference.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
My opinion is like most "performance" upgrades, this is way overpriced.
Did a reman IROC box on my 70 firebird a couple of years ago, DIRT CHEAP and performance was great. Quick ratio with more steering resistance. Any "modern" steering box is going to feel better than the old ones.
1970 C10 Longbed, 250 Inline 6, 3 OTT |
I have a 65 and went with the Cardone rebuilt.
No problems. I am not sure about the 69 but you may have to weld on an additional 1/4" spacers to the frame where the bolt holes are for clearance on the P/S box, just like thick washers. Maybe someone with that year can chime in and clear that up. Looks like 1972BlueC20 is doing it this weekend so he should know. I am with you on not spending extra money if not needed. P/S is the best thing I have done to the truck. Makes those parking lots much easier to navigate. |
#6 | |
I'm not sure but it's either 67 or 69 needs to have the bumper bracket notched out a little for clearance when switching to PS from manual steering. My 72 should bolt right up with no issues I've been told. We shall see this weekend, I will report back.
thanks for all the great replies! i'm looking forward to the experience with the cpp unit. as far as i know the 69 and up don't need any mods to the frame inorder to get the unit to fit...
#8 | |
http://www.summitracing.com/parts/clp-cp50014
#9 | |
I believe that for A1 Cordone you would need the shims. |
#10 | |
![]() Join Date: Nov 2004
It's been a long time since I drove one of these with PS, but from what I remember with the stock box you could turn the wheel with one finger. The advantage you get with the quicker ratio boxes is that the wheels turn faster with less turns of the steering wheel, I don't believe there is any change to the "effort" other than turning the wheel more times. I've had a stock 1972 complete set up sitting in the corner of the garage for the past 6+ years... waiting on me to dimple the frame...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
i replaced my old box with a Red Head, have been happy with it so far. They did not recommend the quick ratio so I went with stock ratio. It's good to me!!
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#12 | |
I may have heard wrong, but I was told that a quicker ratio unit is more like a later model 80's box and that it will have more road feel. I heard the original boxes on these trucks where weird feeling and lacked road feedback. I may be completely wrong. Well, either way...I've already ordered the box and if I don't like it I will send it back and get an A1 Cardone from Autozone or the like. They are def cheaper but I don't mind spending money on good parts...Im already so upside down on this truck I can never sell it even if I wanted....couldn't stand to take that kinda loss!
#13 |
Moderator
![]() Join Date: May 2007
I used Cardone from a local autozone. Works great, no leaks for years now. It was around $120 with exchange iirc.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#14 |
I got one off of a mid 70's C10 and it bolted right up to my 69 GMC. I went from manual steering to power. I don't see any big advantage to getting a "high performance" steering gear for normal street driving. In my opinion, the best way to assure good performance is to make sure to keep the truck well maintained. In other words, replace any worn parts before you upgrade to performance parts.
#15 |
some great information in here! I will wait for your results 72' im in no hurry frame is still at the sandblaster!
#16 |
Redhead all the way. I went stock ratio on the shortbed, trying out the quick ratio on the longbed - haven't rolled it out of the garage yet but I'm expecting it to drive great!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#17 |
All I know for sure is I have the original box and it's about 50 turns lock to lock. If you have power steering and the option for a faster ratio, I'd recommend it.
In my Camaro I have a Saginaw 500 series box (200s Tahoe, basically) and its got a nice feel, good on-center, generally "newer" feeling than the old box.
#18 |
^^^LOL! Mine is the same thing. Feels more like I'm steering a school bus. I will eventually get the AGR quick ratio setup. Mine is actually 4 turns lock to lock & I hate it. The AGR one is a more modern ratio from what they told me (been a while). My son's 72 Nova is 2.5 lock to lock and handles amazing from a steering aspect.
Initially I was going to go with a CPP 500 series...until I read the reviews online, no thank you. |
#19 |
![]() Join Date: May 2013
I put a 78 box in my 68 , its faster , less turns , and has different valving , to stiffen the steering in the centered position , payed around 100 bucks for it , works excellent
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#20 | |
So why the 78? I looked up the p/n and they're a 77-79 truck part. Just a good mix of ratio, etc. that fits without modifications? Do the stock 68-72 hoses work/fit?
#21 |
I googled it over a year or so ago. Many were complaining about leaking issues months after install, some were excess play and others were the box was way too tight feeling. Most of the issues IIRC were with Tri-fives, Novas and Camaros Series 500. When I did my research it was enough to sway me from getting one. And I am a big CPP fan with a lot of their parts on my truck. It seems like a relatively low number that have issues so you possibly won't have any problems. If I get time I'll see what I can find on them again.
#22 | |
what is the problem with the CPP 500 box? I can't seem to find any bad reviews after doing a few google searches. Just wondering since I am expecting this box to arrive Friday and it wasn't cheap. Thanks
#23 |
![]() Join Date: Jan 2008
I like my AGR, good improvement over the stock box
#24 |
The 78 box has worked flawlessly for me , direct replacement from what I can recall , I had a cpp 500 box in a chevelle it was "ok" , very stiff at first , got better with time
#25 |
I put a redhead quick ratio box, from a vendor on this site.
Best investment so far! My Blazer is now fun to drive, before It was sketchy at best. |
