04-12-2016, 09:31 PM | #1 |
Anybody here know if Dorman exhaust manifolds are good?
I am tired of the old headers on my 67.I can get Dorman manifolds for right at $200 for both sides.Part# on LH is 674-201,RH is 674-199
04-12-2016, 09:53 PM | #2 |
Re: Anybody here know if Dorman exhaust manifolds are good?
I'd like to know this too - seems too good to be true that these manifolds can actually be purchased at a reasonable price.
Cast iron quality must vary a lot depending upon the skill of the maker.. but what do I know. |
04-12-2016, 11:14 PM | #3 |
I have used a couple several years ago. I recall they bolted right up and fit just like the factory units. The only negative thing I remember was the casting finish. Not that bad though. I just took a sanding disk to them to clean them up and to remove the part numbers and the profanity word (China) off them then painted them with some high temp manifold paint.
Once you switch back to ramhorns you will wonder why you ever had headers in the first place.
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
04-13-2016, 01:13 AM | #4 |
Anybody know if there are ram horns for big blocks?
72 Chevy C20 LWB-Just what I always wanted. Now, just need more time and money! |
04-13-2016, 06:54 AM | #5 |
I run Dormans on my 67 bbc --no issues yet. I do not tow -- I remember on the 366 tow trucks at work, the heat would crack the oem's eventually.
But I too got tired of headers and like the stock look, fit, and room in engine bay.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
04-13-2016, 09:01 AM | #6 |
I had a set of dorman manifolds on my LS silverado for about 5 years (sold it). They looked and fit like OEM and never leaked. I'd give their ram horns a try.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-13-2016, 09:19 AM | #7 |
I have one on a 72. It fit perfect but as mentioned the finish was not as good as OE. When I blasted it to apply a coating there was some filler in some of the imperfections.
Saskatoon, Saskatchewan Canada |
04-13-2016, 10:20 AM | #8 |
04-13-2016, 10:24 AM | #9 |
What exactly is there about headers to get "tired of"? I am buying a 1972 350 engine and it is equipped with headers.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
04-13-2016, 11:45 AM | #10 |
They take up more room, have more clearance issues, and make changing spark plugs incredibly difficult. Many people also mention that their bolts back out over time and they have trouble getting rid of exhaust leaks.
This is pure speculation but I suspect they run hotter near the head which causes issues near the spark plug wires.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
04-13-2016, 05:58 PM | #11 |
I just put a set on my truck last week, like many have said they are not the best looking out of the box but bolted up real easy and the gaskets that came with seemed good too. Got them from summit, left was like $90 and right was $80 or so
04-13-2016, 06:17 PM | #12 |
I hate headers too..........I just bought these to replace the leaky headers on my '70 K5
they look good...smooth casting and the machining is good quality as well..... will be installing them within the next week or so. http://www.summitracing.com/parts/sum-g9200n
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
04-13-2016, 06:23 PM | #13 |
I've been loving mine for several years now. I went with a set of the 2.5" center dump ram horns for my 4x4 Blazer. NO LEAKS!! This is especially important if you run EFI, and exhaust leaks wreak havoc with the A/F ratio readings.
