04-12-2016, 10:58 PM | #1 |
Is this the pan kit I need for my build?
2006 4.8L Vortec
Going in a 65 C10 that is bagged. Will this pan fit my 4.8? Or is it for a 5.3? I figured I would ask the forum. Since a phone call wouldnt work at this hour. http://www.gmpartsdirect.com/oil-pan...3/?parent=1111
1965 C10 Project |
04-13-2016, 04:11 AM | #2 |
Re: Is this the pan kit I need for my build?
T will fit your engine, but since the truck is bagged it might not be the best option because it may hang down a little too much depending onhow the engine is mounted.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-13-2016, 10:51 AM | #3 |
Fabricate till you "puke"
I used that pan on my swap (static drop).....if you plan on laying the truck on the rails, you would probably like the F body pan. the hotrod pan hangs about 1" below the cross member in my truck.....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-13-2016, 11:54 AM | #4 |
I think this would be better. It is what I used on my bagged truck.
http://www.superchevyperformance.com...p/12628771.htm |
04-14-2016, 03:35 AM | #5 | ||
Is yours a 4.8 or does it matter between 4.8 and 5.3? What engine mounts are you using? Homemade mounts? Thats for the info everyone!
1965 C10 Project |
04-14-2016, 08:02 AM | #6 |
4.8 and 5.3 are the same engine block wise, just so you know.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
04-14-2016, 09:25 AM | #7 |
What he said. My truck doesn't lay frame, but it's low enough that I didn't want the pan to hang below the crossmember. I used eBay conversion plates and a set of new factory rubber mounts for a SBC. I think they are made by ICT BILLET
04-14-2016, 01:30 PM | #8 |
Get the Camaro pan. That seems to be what most are successfully using. Mine is not too low but I like the fact it is above the cross member. Plus you can keep the engine as low as possible, that will help on the hump clearances as well.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-15-2016, 05:04 AM | #9 |
Thanks everyone.
1965 C10 Project |
04-15-2016, 05:29 PM | #10 |
for refernce: CTS-V pan is flush with crossmember when motor is mounted on stock towers and Dirty Dingo Sliders
