Old 04-13-2016, 08:44 AM   #1
chrismoore701
chrismoore701's Avatar
Look what I found, square body step side gas filler hose
Holy cow, look what I found. I guess it is all in how you word your search
http://www.fillernecksupply.com/1978...l-filler-hose/
This is worth buying just to see if it will work
http://www.oreillyauto.com/site/c/de...0065&ppt=C0075
Trying to figure out if the earlier years will fit a 79. This company has them for both sides
http://www.gastankdepot.com/chevy-gm...ler-necks.html
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-13-2016, 09:20 AM   #2
flashed
Re: Look what I found, square body step side gas filler hose
Good to know ,thanks for sharing .
flashed is offline   Reply With Quote
Old 04-13-2016, 09:32 AM   #3
Shugalou
Shugalou's Avatar
Nice find but WTF 50 bucks! And it's outta stock...I need to buy one as mine is opening up at the ends. I double clamped it and it stopped leaking but I would like to replace eventually.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 04-13-2016, 09:56 AM   #4
NJ C10 Guy
I think I remember finding this a while ago, and it was out of stock then. Were you able to order one? Might be something that's been on the website but unavailable for some time...
NJ C10 Guy is offline   Reply With Quote
Old 04-13-2016, 10:09 AM   #5
chrismoore701
Well thanks for the bad news. I was excited for a minute. Anybody know if the one from the earlier years will fit a 79?
Chris
Old 04-13-2016, 10:31 AM   #6
NJ C10 Guy
I'm not 100% sure it was the same website. I looked high and low for one myself (still looking actually). Hopefully they still make them and will get them soon.
Old 04-13-2016, 10:39 AM   #7
chrismoore701
I called filler necks supply they are out. I just called the dealer. They are out
I am currently chatting with Classic Parts of America and they are going to pull one off the shelf and measure the length and see if it will work. I will keep you posted. If it does fit I think I will buy two (2) and cut and twist the other side with a piece of exhaust pipe or conduit. Depends on what I can find
Chris
Old 04-13-2016, 10:42 AM   #8
chrismoore701
Classic parts just told me it is 11.5" from inside to inside straight measurement. Going to measure mine tonight and see if it will work. mine is cut short, does anyone have a full length piece they can measure?
Chris
Old 04-13-2016, 02:25 PM   #9
El Dorado Jim
I bought a couple from LMC a few years ago for a '79 http://www.lmctruck.com/icatalog/cc/full.aspx?Page=49 and 73-78 will not work...
El Dorado Jim is offline   Reply With Quote
Old 04-13-2016, 03:09 PM   #10
chrismoore701
Why will they not work? Lmc only has the filler hose for 73-78 stepside. Not 79.
Chris
Old 04-13-2016, 06:14 PM   #11
chrismoore701
I measured my hose tonight and it is just over 9.5". But it is cut short. I am not sure if I actually cut off two inches. Either way. Worse case scenario my 79 seems shorter than the 73-78. So they should work. What do you guys think?
Chris
Old 04-14-2016, 01:43 AM   #12
El Dorado Jim
will probably work...I was thinking fleetside...sorry
Old 04-14-2016, 06:40 AM   #13
Tilt
When I did the LS swap on my 86 steps ide, I only went back with the passenger side tank. I put the driver side hose and filler neck up for safe keeping. If I can remember when I get home today, I'll measure it for you.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 04-14-2016, 07:28 AM   #14
77 ChevySport
FWIW: This topic has been discussed on this board many times. Do a search and you can find all kinds of input. Bottom Line for me is:
I HAVE BEEN LOOKING FOR A SPARE INLET HOSE FOR A 1977 STEPSIDE SHORTBED FOR MANY/MANY
YEARS! CONCLUSION> DON'T BELIEVE I WILL EVER FIND ONE THAT FITS--PERIOD! Larry
P.S. I bought many spare parts from GM when I bought this truck but never thought to buy this item>My Bad! (Long discontinued from GM)
77 ChevySport is offline   Reply With Quote
Old 04-14-2016, 10:16 AM   #15
chrismoore701
I just bought a pair from gas tank depot. See what happens. Thanks for the offer to measure but will find out soon enough
Chris
Old 05-17-2017, 10:03 AM   #16
BamaDave
Did the pair work from gas tank depot?
BamaDave is offline   Reply With Quote
Old 05-17-2017, 10:22 PM   #17
Peter S
Peter S's Avatar
Is this what you are looking for?
http://www.classicparts.com/1973-78-.../#.WR0EldyNYkK
-Peter
1978 K10 stepside
Peter S is offline   Reply With Quote
Old 05-20-2017, 12:45 AM   #18
superdav
Oreilly's does have some cool stuff
http://www.oreillyauto.com/flux-capacitor.html
superdav is offline   Reply With Quote
Old 05-20-2017, 06:24 AM   #19
chrismoore701
Ok here is the deal. Not a direct fit but they work. I picked up a pair from
http://gastankdepot.bmobilized.com/?...ler-necks.html
So I bought I think like an 85 bed. Bought new plastic filler pieces that the necks connect to. I had to drill them to get my 79 necks to fit. The passenger hose was a direct fit. The driver side I had to shorten 2 inches. But it squeezed together. I think they will work. Have not tried to fill them yet. Still trying to install my steps. Ran out of stainless bolts. Back out there tomorrow
Chris
Chris
