Old 04-13-2016, 10:24 AM   #1
monte0185
monte0185's Avatar
Water Pump Pulley Help Please
On our 86-91 BBC trucks the alternator belt is a serpentine belt. I was wondering if anyone has the part numbers for the water pump pulley that also has the single v-belt groove as well? Im trying to convert my Pro-Street BBC over to this to ease my charging issue. Pic of setup For reference..
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-15-2016, 10:18 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Water Pump Pulley Help Please
Your is mostly like a 7 in pulley water pump. 69-72 there to ID: #'s BB 7" 33956666 ID: #'s SB 7" 330556 single grove.
V8 73-77 single grove water pump 7" ID:# 14023154 CC
hope this helps
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-15-2016, 10:42 PM   #3
monte0185
monte0185's Avatar
hope this helps
I have the later model long nose pump and currently have a double groove v-belt pulley. What I'm wanting to do is keep the double groove but make the alternator a serpantine belt like the 86-91 motors have. If that makes sense.
Old 04-15-2016, 10:49 PM   #4
monte0185
monte0185's Avatar
This is a pic of my setup but it has a cs130 amp now and has been rewired.
Old 04-15-2016, 11:24 PM   #5
Pontiac1976
Ok so you have serpentine belt. on the out side, but you have a two belt pulley on the water.
If I got this right now. You want a serpentine belt on the out side of the water pump pulley and a in side V belt. Wright
Then you are looking for the 84-86 Firebirds / Camaro could be the V6 305-350 set up. I got one of these for my 76 Lemans . NOT Know the #'s on them of hand not sure where I put it to look at them. Think the Monto Carlo had this set up to but can't remember what year and what motor set up.
Old 04-15-2016, 11:35 PM   #6
Pontiac1976
LINK: https://marchperformance.com/aluminu...mp-pulley.html
This might be the one your looking for?
Old 04-15-2016, 11:38 PM   #7
monte0185
monte0185's Avatar
Close. I just have v-belts now but want to replace the alternator belt with a 5 rib serpantine belt just like what's on the 454 setups from 86-91. The first pic of the black truck is my 86 that had the setup I'm looking for. The red truck is my pro street that I want to copy the serpantine setup from the first one. I can find the matching crank pulley but I can't find the water pump pulley but I think it may be the same as the sbc like you mentioned earlier but I can't find any part numbers to prove that one way or another. I found a smaller wider pulley for the alternator v-belt so I may just scrap this idea and go with it.
Old 04-15-2016, 11:43 PM   #8
monte0185
monte0185's Avatar
Found that one to but says 305/350 so not sure it'll fit on my bbc. But it's as close as I've found to what I'm looking for.
Old 04-16-2016, 08:11 AM   #9
Pontiac1976
Try to look in the scrap yards junk yards for the 84-86 Firebirds / Camaro could be the V6 305-350 they have the set like this if you find one grab alt or ( just the alt Pulley ) if you have a Batt impact gun, water pump pulley, belt or mark down the size, keep eye on e-Bay for them.
