Old 04-13-2016, 02:14 PM   #1
forestb
forestb's Avatar
Straightening 1/2 inch aluminum fuel line
I am trying to use a peace of aluminum fuel line to run the wires for my tail lights through on my step side. I bought a length of 1/2 inch aluminum but it is in a coil. What is the best way to straiten it?
forestb is offline   Reply With Quote
Old 04-13-2016, 02:49 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Straightening 1/2 inch aluminum fuel line
Open it up at the end standing the coil on end and pulling/rolling the coil away. After you get the length you want roll it between two pieces of plywood is what I heard someplace.
There are tools for that but they aren't cheap.
http://www.eastwood.com/tube-straigh...CCODE=BNB00152
http://www.brakequip.com/shop/tube-straightener-bq1028
Or you can make your own:
http://www.garagejournal.com/forum/s...53#post3140153
Old 04-14-2016, 12:33 AM   #3
vetnat
I have also heard of people using a block of wood several inches long, with a hole just slightly bigger than the outside diameter of the tube bored through it. Pull the tube through the hole in the wood to straighten it.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 04-14-2016, 12:45 AM   #4
62stepside longbox
62stepside longbox's Avatar
That's exactly what I did with my 3/8 aluminum fuel line.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-14-2016, 02:00 AM   #5
suburban99
suburban99's Avatar
Unroll tube and lay on floor. Put your feet together on top of the tube and roll over top of the tube. Back and forth and up and down the length. I have straightened many pieces of 1/2" soft copper this way over the years... (wish I had a video)..
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 04-15-2016, 01:17 AM   #6
DakotaKid
the 4x4 block of wood with the hole is the exact way i do it. it work really well, I use it for Cunifer and Stainless. im sure aluminum will be easy. Just drill a hole a little bigger than the tube and pull it through. 4x4 block of wood works great.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 04-16-2016, 03:33 AM   #7
bumwine
bumwine's Avatar
I stumbled upon these straighteners and they work good. Way cheaper compared to some others I've seen
http://www.kwixuk.com
bumwine is offline   Reply With Quote
