![]() Join Date: Jun 2015
th400 kickdown?
my 72' C20 when bought did not have the the kickdown harness and the trans throttle control kickdown switch is broken.so i do not know how it attaches the the gas pedal.could someone post a pic with what the bracket is called
Re: th400 kickdown?
ok i found this pic and this is everything i need. but been looking online for parts and cant find them. any good sites you buy from
Re: th400 kickdown?
i bought one from lokar when i was still running the h400. Not sure if your wanting it to be 100% restored but that dude was super easy to install as well as 99% hidden. You simply run the supplied cable from the carb to the kick down box which mounts on 2 tranny pan bolts. Plug it into the transmission and run a 12v keyed power source. done
Re: th400 kickdown?
found the parts i needed at Restoration Parts Source and at a good price. thanks
Re: th400 kickdown?
Just manually shift that biatch
1972 C10 - It might be old, but it's not slow |
Re: th400 kickdown?
just a thought I wonder if you could use a micro switch set up like from a NOS kit probably easier to find and hook up
