04-14-2016, 12:58 PM | #1 |
Adding Cruise Control question
Does anyone know how difficult it is (and costly) to add cruise control to an '83 that didn't come with cruise? It has every other option, air, all power, etc. but not cruise.
I don't want an aftermarket deal; would like to keep it looking factory. Does the entire column have to be changed out? I have terrible neuropothy in my feet, along with a bad arch on my right foot, which makes it painful to drive long distances without cruise. But I love to drive my truck and would like to add cruise if it's not a crazy amount of work. Any help appreciated. |
04-14-2016, 01:46 PM | #2 |
I have no time for this
Re: Adding Cruise Control question
There is a way to use the cruise control from an early nineties truck that works very well. I saw one being used in a 66 Chevy truck a long time ago. I think it had an electric/ mechanical speedo drive and the rest was just a matter of wiring it and mounting the cruise servo. It seems to me he was using a van column. The whole truck was built from pick a part lots.
1986 Chevy short box ( PROJECT ) 1994 Chevy Blazer lifted 6" 2009 Gmc 2500 HD 1999 Hugger orange Camaro SS 2007 BMW X5 Sport |
04-14-2016, 02:00 PM | #3 |
I installed cruise on my '87 back when it was new.
I used a GM Dealer over the counter installation kit. I'm sorry but I don't recall the part number or any (helpful) details like that. The column was not affected (you do have to change out the turn signal stalk itself). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-14-2016, 02:51 PM | #4 |
RPM,
I added factory cruise to my 75 using the kit that was available from GM. It had all the pieces. It worked ok but not like the current cruise controls. I am currently building an 86 and want to add cruise to it. I have gathered all the pieces (so I think) from donors (PYP) and hope to install it and have it work. Won't know till later this year. Hoping this works out ok. Darwin |
04-14-2016, 03:40 PM | #5 |
I have an 83 with factory cruise and it is not reliable - works when it wants to.
The factory set up in an 83 has a left side cruise control on the turn signal stalk, servo with link to throttle, a circuit board in a red plastic box under the dash, and extra vacuum reservoir on the firewall, plus wiring. The circuit board and CC turn stalk are no longer available. So, I would go with electronic aftermarket cruise and forget the factory set up. You can remove the aftermarket components if you want to in the future. The 83 has a one year only CC stalk and I believe one year only circuit board. Vacuum controlled CC is really outdated technology and not worth trying to install it, IMHO. |
04-14-2016, 03:58 PM | #6 |
My 79 has it. The old vacuum operated setup mounted on the driver inner fender. Works fine. About 20 years ago I had the unit rebuilt at GM, they had a service for that. It was sometimes hunting for speed. The little magnet/brushes deal inside gets worn I suppose. It's worked flawless since.
Would be a pain to add this type of system anyway, there's a lot of parts and pieces to it. |
04-14-2016, 06:09 PM | #7 |
I guess I am wondering why you are opposed to a new aftermarket cruise? The new ones work great and the handle looks close to factory. They are simple and pretty much trouble free. You can get one from any of the street rod parts places. They are all made by rostra as far as I know.
04-14-2016, 10:54 PM | #8 |
Moderator
The 1988 and later Electro Motor cruise control can be used on any vehicle. It's fairly easy to retrofit. This module has been used to add cruise control to a lot of different vehicles.
*** EDIT*** Mine is from a late 80's T400 chassis truck. You should be safe using one from a TBI vehicle with 2K square wave VSS through at least 1992. From 93 on the expected VSS signal probably will be different. You'll need the Electro Motor cruise box with cable, VSS, Turn signal stalk, and brake/clutch switch(s). If you can liberate the entire cruise sub-harness it'll have the mating connectors for the Engine bay module and the switches in the cab. The Metripack 150 connector on the cruise box...
The GM Electro Motor Cruise Service Training Textbook is on the 73-91 manual page linked in my signature.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-18-2016 at 11:07 AM. |
04-15-2016, 02:22 PM | #9 | |
Thanks for everyone's input. I'm just glad to know there are plenty of options. -RH- |
04-15-2016, 02:56 PM | #10 |
the servo unit actually looks similar to the electro motor one that hatzie posted above. The unit has a long enough cable on it that it can be tucked away so it doesn't stand out. Like I said before the control handle is a direct replacement for the turn signal lever in truck now.
04-16-2016, 09:05 AM | #11 |
Moderator
The Rostra and Dakota Digital units can use Factory Cruise Control switches and Factory VSS signals.
The aftermarket servo unit has DIP Switches to select the VSS signal type and frequency as well as the stalk control switch type (Normally Open or Normally Closed). The downside to the aftermarket units is the cost, right around $300, with not much ease of installation gain. The 90's GM cruise Servo Box can be purchased as cheap as $35 with a cable on evilbay or your local pick-n-pull. With new or used servo you'll be fabbing a throttle bracket and fabbing/installing a sub-harness to mate with your servo module choice. The pedal & stalk switches and VSS are not included in the $300 price. The cleanest inside the cab installation for either system is to source GM cruise control pedal switch(s) with brackets and connector shells, GM optical VSSB and connectors, and GM type cruise stalk. Pedal switches and brackets are self explanatory. Liberate em from a Cruise III truck. The Packard 56 mating connectors are still available. Dakota Digital sells cruise control turn signal stalks that look factory. For your 83 with dimmer still on the floor and wipers still on the dash... you can replace the turn stalk with the HND-3 turn signal stalk I used on my 76. To the unwashed masses it will look factory. http://www.summitracing.com/parts/dak-hnd-3 It's worth noting that the HND-3 I purchased came with a pretty cheesy Mini Mate-N-Lock connector and 22ga wires. I used a 4 position Deutsch DTM connector pair carefully wire tied for strain relief. You could solder and heat shrink 4 6" sections of 18awg wires to the tiny 22-24ga wires and use whatever connector floats your boat. I used a Mini ISO relay controlled by the stalk switch to turn on the cruise control. I figured the switch would last longer if the full servo module "on" current wasn't running through it but it's probably not necessary. The stock Cruise III GM optical VSSB on the instrument cluster starting in 81, 82 or 83 will output a 2,000 pulse per mile square wave. According to this thread they all had provision for the optical sensor... http://67-72chevytrucks.com/vboard/s...22&postcount=5 The 1984 Cruise III textbook explains the pinout of the optical VSSB module. The Fiero guys seem to think the later Green modules had more and better signal conditioning. You'll need to liberate the now obsolete GM Delphi 12034117 & 12015686 card edge connectors from a salvage vehicle. The optical VSSB units aren't that unusual on the 80's GM trucks and cars. EDIT*** I've dug into these connectors. I believe the terminals are Delphi 12040502 Edge Board Terminals but I'm not positive on my identification. I'd recommend getting about 6-8" of wire along with the terminals on these obsolete Optical VSSB card edge connectors.
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-17-2016 at 06:29 PM. |
04-16-2016, 02:06 PM | #12 |
This is the route I am going to go if I do this. The reason my guy used the van column was the 66 truck doesn't have the prndl in dictation on the dash but the van column has it just below the wheel.
04-16-2016, 02:34 PM | #13 |
Hatzie,
Well thank you for the info. I picked up an Electro Motor controller (from a 95) from PYP this morning for an ungodly sum of $22 (thats $8 US :-)). I have yet to decide if I will use it (I also have everything stock for my 86) but I am keen to learn more. Darwin |
04-16-2016, 03:44 PM | #14 |
Moderator
The Cruise Control GM Service Training Group Textbooks for the three major iterations of semi-standalone cruise controls are in the 73-91 manuals link. They're fairly short textbooks but there's a lot of information in them.
70's Cruisemaster speedometer cable driven vacuum mechanical units that are hard to find decent replacements for. 80's Vacuum Electronic Cruise III 90's Electro-Motor motorized servo cruise control units that are pretty much the same animal as Dakota Digital and Rostra sell. You can liberate the small sub-harness attached to the cruise control module, pedal switches, column switch, and ignition power. AFAIK that 10 position Metripack 150 plug is an odd duck not a standard Metripack 150... The actual terminals are regular Metripack parts but the shell is specific to that cruise control module. You'll want to find a 1984-1991 truck with the cruise control pedal switches for the switches and brackets. You may be able to use the G-Body or B-Body pedal switches. 83-86 models use common Packard 56 connector shells and terminals that are still available not sure about later rigs.
http://www.amazon.com/Delphi-Packard-Weatherpack-C... I prefer the, slightly more coin but still inexpensive, ratcheting five cavity "universal" tools because I can be positive the crimps are done. They are more coin but they are real Delphi crimp tools and can likely be sold for 2/3 or more of new as long as you take care of them. The only downsides to these is the lack of terminal holders that keep the terminal from rotating in the crimp cavities and it does not crimp the strain relief/cavity seal with the wire in one operation. If you slightly pinch the crimp ears so they are not spread as wide apart the terminal will not twist and you'll get a nice crimp on the wire and on the jacket or seal every time. The family specific tools cost around $400 each and they are limited to one connector family. These more universal tools are around $90.
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-17-2016 at 04:49 PM. |
04-16-2016, 03:57 PM | #15 |
Moderator
The earlier G series Vans had the ignition key in the dash too just like your 66.
And please let us know if and how your repairs were successful. |
04-16-2016, 04:43 PM | #16 |
Hmm. Will that work with a stick? SM465
1982 K10 SWB 1987 V20 - Sold - Doh! |
04-16-2016, 06:29 PM | #17 |
Moderator
Cruise control is not oogy boogie black magic. Generally it's pretty easy. Especially using these all-in-one servo motor modules.
Manual is not that different from automagic. You need two pedal switches with contacts open when the pedal is pressed... the clutch override switch is wired in series with the brake override switch so either pedal will shut down cruise. Wiring Diagram from the Electro Motor Cruise textbook. 25007463 Optical VSSB Pinout with the obsolete Delphi connector part numbers from the Cruise III textbook.
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-16-2016 at 06:39 PM. |
04-16-2016, 10:55 PM | #18 |
Hatzie,
Could you help explain what I am experiencing My wire connector on the cruise unit looks to be the same as the photo you posted (wire colors and position). But when compared to the wiring diagram A and B are good - wiring diagram and wire colors on my connector C - diagram calls this dk green and I have gray with black stripe D - Diagram calls for brown wire and I have purple E- agrees F- diagram calls for pink and I have dk brown G- not on diagram and I have white H-blank J- not on diagram - I have lt blue wire with black stripe K - digram has brn white stripe - I have green with white stripe This came for a 1995 Chevy Suggestions? Thanks Darwin |
04-17-2016, 12:09 AM | #19 | |
Moderator
The terminal position functions, by letter, in the textbook diagram are the same as the 1995 diagram below even tho the wire colors differ. Terminal C is still from the stalk Resume/Accelerate switch no matter what color wire is in C. Terminal K is still the VSSB Cruise 2K Squarewave signal no matter what color wire is in K. Terminal F is still Ignition power... and on it goes... Hook up A, B, C, D, E, F, G, & K. You will not be using the PCM connection on terminal J or the PCM servo inhibit wire on Terminal H. Cut the wires on these positions off close to the servo module connector and cover the ends with Adhesive lined heatshrink or remove the terminals completely and insert 15324928 Metripack cavity plugs in the empty holes. A wire on Terminal G could be teed into the wire between the brake lamp switch and the steering column. **EDIT** Some modules, but not all, need this to cycle before they will allow cruise to be engaged. Mine did not but YMMV. Easier to just hook it up. Since your sub-harness came from an automatic transmission vehicle with a TCC Stoplamp Switch the pedal switch wiring is slightly different than what you need. Terminal D has a Purple wire instead of a Brown/White wire found on the manual transmission trucks and it was connected through the TCC Stoplamp switch to the fuse panel. Wire color is irrelevant. You can print the below diagram out and mark it up in red pen or pencil with the colors in your sub-harness if that helps you keep track. Removing Ignition power from the Cruise Release Terminal D by pushing in the properly wired clutch or brake pedal will temporarily release cruise. Unlike setting the stalk switch to Off this keeps the last speed setpoint in memory so you can resume by selecting Resume-Accel. The Terminal A Gray wire is a handy source of ignition power to keep the sub-harness clean and neat. To setup the "Cruise Release" switch circuit...
1995 Electrical Service manual Cruise Control wiring diagram...
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-18-2016 at 11:11 AM. |
04-17-2016, 08:11 AM | #20 |
Interesting reading and great info provided. I have been wanting to try this on a truck I swapped a TBI unit onto, but I used an add-on VSS. It goes inline in the speedo cable, and I believe it provides a 2k square wave signal. I wonder if I could tap into this signal to run the cruise unit mentioned above?
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
04-17-2016, 10:33 AM | #21 | |
Moderator
What rig did you get the TBI wiring and controls from... TBI DRAC or VSS Buffer Amplifiers, if you installed one, have ECM, Speedometer, and cruise control VSS output channels. Some F-bodies and other GM rigs in the mid 80's had a VSS buffer with multiple output channels. Part # 25071437. The ECM may actually have a Cruise control VSS output that may work depending on what it was liberated from... Your other option is... RockAuto has new Optical Pickup VSSB units from GM Restoration Parts for around $50. http://www.rockauto.com/en/moreinfo....sn=507&jsn=507 If all of the 81 up speed heads really have provision for optical VSSB, and you have an 81 or newer truck, it would be extremely easy to install.
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-17-2016 at 11:09 AM. |
04-17-2016, 11:25 AM | #22 |
EFI Connection has a pigtail available for the Electro-Motor cruise units, their wire colors are based on the '96-'02 wire diagrams but I believe the plug is the same for all units.
https://www.eficonnection.com/eficon...px?ItemId=1207 Nate
Current Project: 1990 V3500 CC dually. |
04-17-2016, 12:04 PM | #23 | |
04-17-2016, 12:43 PM | #24 |
Moderator
The EFI Connection pigtail isn't a bad deal for most folks. If you don't do a lot of this you'll spend almost the same price on the parts as they are charging for their pigtail. If you have spools of wire and Metripack parts in your arsenal...
EFI connection uses a mix of 20ga & 18ga wire. If you're rolling your own you can use 18ga GXL jacketed wire for all seven or eight wires. A 10 color assortment of 25' coiled 18awg GXL wire from the Wire Barn is around $34 US. Delphi Metri-Pack 150 connector part #s for the Cruise Module.
And please let us know if and how your repairs were successful. Last edited by hatzie; 04-17-2016 at 04:36 PM. |
04-17-2016, 03:47 PM | #25 |
Hatzie,
Thank you for all of the great info. Very very helpful. Darwin |
