Old 04-14-2016, 04:22 PM   #1
Samz
'60 wobbly steering wheel
Hello,
I'm new to this forum. I just picked up a '60 Chevy 1/2 ton short bed step side truck. It has a Chevy 350 and 400 auto. The truck is pretty nice and drives great. The PO did a lot of work to it, to include putting in a chrome tilt steering column (shifter and ignition on the column) that he purchased new off of eBay (about 200 bucks per the receipt). I didn't notice when I was checking out the truck before I bought it (I guess I was too excited! haha), but on the drive home today I noticed that the steering wheel wobbles quite a bit. She steers just fine though. I thought I asked here before I go taking things apart, to see what the problem might be.
I'm sure I'll be asking a lot of questions on this forum in the near future. Thank you in advance.
Samz is offline   Reply With Quote
Old 04-15-2016, 11:11 AM   #2
slepysal
slepysal's Avatar
Re: '60 wobbly steering wheel
Make sure the nut that holds the wheel ( NOT YOU! )is tight if it is an after market wheel , check to see that the hub adaptor is tight, also check to see the mounting bracket that holds the column is also secure
Welcome and please post pics !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 04-15-2016, 03:38 PM   #3
Samz
Thanks for your input SlepySal. I'll go check those things now. It is an aftermarket wheel and tilt steering column.
Old 04-15-2016, 05:29 PM   #4
60chevyjim
60chevyjim's Avatar
if it wobbles where it tilts , there are 4 bolts that hold it together inside of the column .
I used to rebuild GM tilt wheel columns in phila. pa.
60chevyjim is offline   Reply With Quote
Old 04-15-2016, 05:55 PM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
quite common , my suburban is doing that right now...
if that is what it is, all you have to do is pull the wheel off, and you need a special puller to get the "hog"?? retaining ring off the wheel lock piece, then you can tighten up the column bolts.
Old 04-18-2016, 01:44 AM   #6
Samz
Well, I got her all tightened up. It was that nut that worked it's way loose a bit. I tightened it down and all is well now. Thanks for your input....
1960 C10, shortbed, step side, big back window, 350, Turbo 400
