Old 04-14-2016, 10:48 PM   #1
cheepin
Starters
I think my mini starter I am running in my crawler may have died. SB406 with block huggers. I had to run the mini to clear the headers. The stock starter was just a tad too long. Anyone know of a cheaper stock starter that is no longer then 9"?
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 04-14-2016, 10:55 PM   #2
69heavychevy
69heavychevy's Avatar
Re: Starters
mid to late 90's gm truck gear reduction starter.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 04-14-2016, 10:57 PM   #3
69heavychevy
Re: Starters
Have to use the correct starter bolts though, unfortunately I don't have it right at the moment. I'm sure someone will chime in with that info...
Old 04-14-2016, 11:04 PM   #4
cheepin
Re: Starters
I will check that out. Thanks
Old 04-15-2016, 12:42 PM   #5
tucsonjwt
Re: Starters
The options that are most popular are the gm high torque min starter (red bow tie one) and the Hitachi mini starter. Have used both on my 454 83. The GM starter was a little less powerful with heat soak so I went with the Hitachi, but now the Hitachi makes a high pitched squeal and no start when hot occasionally, even though the auto electrical shop who installed it says it is installed and shimmed correctly. I am debating about putting the bow tie starter back in - it had a slow drag when the engine was hot but it always started.
In any case, I found I needed a reflective heat wrap (about $20) around any starter to help with heat soak.
tucsonjwt is offline   Reply With Quote
Old 04-15-2016, 03:51 PM   #6
MikeB
MikeB's Avatar
Re: Starters
Over the years I have used two GM/AC-Delco permanent magnet starters from mid-90s 5.7 liter engines. They are small but powerful and are available for either 153- or 168-tooth flexplate/flywheel. Sorry, but I don't know the length or P/Ns.
RockAuto shows several different P/Ns at $40 to $140. Your best bet will be a local parts store, so you can put your hands on one and return it easily if it doesn't clear your headers.
IMO, new or rebuilt AC-Delco starters (actually rebuilt by AC-Delco) are much more reliable than aftermarket mini starters.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
