Old 04-15-2016, 11:47 AM   #1
veltex
veltex's Avatar
GMC dimmer
Anyone know who makes a 65 gmc dimmer switch? The three tab arrangement has the top one sideways and the bottom two up and down, all the replacements Ive seen so far have all three tabs sideways. I hate to change the factory plug unless I absolutely have to. Thanks for the help.
beater 65 gmc at the moment
veltex is offline   Reply With Quote
Old 04-15-2016, 02:25 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: GMC dimmer
Like this?
Old 04-15-2016, 02:26 PM   #3
aerotruk63
aerotruk63's Avatar
Re: GMC dimmer
Hate not having edit option.
Link:
http://www.allbatterysalesandservice...fm/4,9241.html
Old 04-15-2016, 02:40 PM   #4
64shortbed
64shortbed's Avatar
Re: GMC dimmer
Standard motor products DS70 or DS70T. Same switch just the T series one is cheeper. $8-$16.
64shortbed is offline   Reply With Quote
Old 04-15-2016, 08:52 PM   #5
franken
Re: GMC dimmer
Usually the trouble with dimmer switches is lack of use. Click it 10 times and it'll work fine.
franken is online now   Reply With Quote
Old 04-16-2016, 12:33 AM   #6
veltex
veltex's Avatar
Re: GMC dimmer
Hey thanks all, that looks like it, mine works fine its just broken at the mount and moves around a lot. So gmc used a ford part?
Old 04-17-2016, 08:00 AM   #7
karlbenz
Re: GMC dimmer
I thought they all used the same?? my 64 gmc uses the standard one
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 04-17-2016, 08:02 AM   #8
karlbenz
Re: GMC dimmer
I think someone switched yours out
http://www.oreillyauto.com/site/c/de...+dimmer+switch
1965 Chevy C60
Old 04-18-2016, 04:26 PM   #9
64shortbed
64shortbed's Avatar
Re: GMC dimmer
If its the other one then its a standard motor products DS72 or DS72t.
