Old 04-15-2016, 07:52 PM   #1
tommy217xxx
tommy217xxx's Avatar
Dash question
Hey everyone, I have a 76 gmc 1500 and I think it has an 81-88 era dash in it. How different are they? I don't think it's a problem unless it doesn't mount the same way.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 04-15-2016, 09:34 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: Dash question
LINK: http://bowtieguy.proboards.com/threa...ce-bezels-fits
This should help you
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
