Old 04-15-2016, 11:27 PM   #1
Question, 1981 and 1985 sheet metal interchangeable?
I just got home with an 85 Stepside that needs a few things. I have a nice 81, 3/4 ton donor truck. Same stuff?
Old 04-15-2016, 11:56 PM   #2
nvrenuf
Re: Question, 1981 and 1985 sheet metal interchangeable?
Yep
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 04-16-2016, 03:12 AM   #3
andrewmp6
Yeah they are the same.
andrewmp6 is offline   Reply With Quote
Old 04-16-2016, 10:33 AM   #4
Excellent! Thank you
Old 04-18-2016, 09:04 AM   #5
As I'm doing some homework I noticed in some pictures that the 85 Chevy seems to have 2 different front ends, a single headlight with turn signal below the the light and double headlights, one on top of the other. What option or package made the difference?
Old 04-18-2016, 10:01 AM   #6
andrewmp6
I believe the single lights was the lower trim options trucks while the duals was the higher trim trucks.
Old 04-18-2016, 12:06 PM   #7
Keith Seymore
Keith Seymore's Avatar
RPO V22 "Uplevel Grille".
The base grille single headlamp version was Custom Deluxe and Scottsdale (Z62). You could add V22 (dual headlamps) to a Scottsdale if you wanted - which is what I always did.
Uplevel grille was included with the Silverado (YE9) package.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-18-2016, 12:15 PM   #8
Many thanks Keith!
...the guru has spoken
Old 04-19-2016, 11:39 AM   #9
Keith Seymore
You are welcome. You happened to ask one I knew (or remembered) the answer to!
K
1979-1986
1986 - 2019
