Old 04-16-2016, 10:30 AM   #1
crazyjim
crazyjim's Avatar
Electric problem
I put a new battery in when I bought the truck, work fine till lately. I changed bad fuse now battery drains all the juice out of the battery when it sets over night cant figure it out.
crazyjim is offline   Reply With Quote
Old 04-16-2016, 10:34 AM   #2
chrismoore701
chrismoore701's Avatar
Re: Electric problem
Turn the lights out in garage. Pull battery cable off. Touch it to the battery. If it sparks you have a load. Pull the fuses out one by one and Check the spark on the battery. Do this until no spark. That circuit has your draw
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-16-2016, 10:36 AM   #3
hatzie
Moderator
hatzie's Avatar
I usually pull all the fuses and put em back in one at a time... Easier to keep track of which ones you haven't tested yet.
I also usually use a meter between the battery and the ground cable. Use the 10A fused test lead port on the meter. Set it for DC Amps. A reading over 0.025 Amps (25 ma) is way too much. On these trucks background draw should be closer to 10ma or even less.
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-16-2016, 10:50 AM   #4
nonstop
What does the bad fuse control? Something caused it to blow. Pull out the fuse you replaced and leave it empty. If the battery stops draining, then you now know where you need to start looking.
nonstop is offline   Reply With Quote
Old 04-16-2016, 11:25 AM   #5
crazyjim
crazyjim's Avatar
Tail lights.
Old 04-16-2016, 11:37 AM   #6
nonstop
That's the circuit I would start checking out first.
Old 04-16-2016, 11:43 AM   #7
hatzie
Moderator
hatzie's Avatar
What's the fuse marked?
What year is your truck?
Depending on the year there can be a fuse for the running lamps and a different fuse for the brake lamp circuit. Several other circuits share those fuses depending on what year you have.
Old 04-17-2016, 11:08 AM   #8
crazyjim
crazyjim's Avatar
Found the problem it was the blower resistor on the heater I want to thank every body for their help Jim.
Old 04-17-2016, 11:39 AM   #9
Pontiac1976
Pontiac1976's Avatar
Good find, glad you got it working. Thanks for let ever one know the fix.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
