Old 04-16-2016, 10:21 PM   #1
66clow
66clow's Avatar
What do these wire go to?
Trying to figure out what the three green wires go to? I know they look kinda scary at the fire wall. 69 c10
66clow is offline   Reply With Quote
Old 04-16-2016, 10:55 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: What do these wire go to?
I do believe those go to the backup light switch on a manual transmission
Livrat is offline   Reply With Quote
Old 04-16-2016, 11:01 PM   #3
66clow
66clow's Avatar
The truck was a manual but converted to auto. Can they be reused for the auto?
Old 04-16-2016, 11:15 PM   #4
Livrat
Member #1049
Livrat's Avatar
A truck with an automatic has the switch on the steering column, you could remove those wires completely and unhook the same inside the cab on the fuse box and reroute them to the column mounted neutral safety/ backup light switch.
Old 04-17-2016, 10:49 PM   #5
jdalexa84
That melted tan wire above them looks scary to me.
jdalexa84 is offline   Reply With Quote
Old 04-17-2016, 10:55 PM   #6
66clow
66clow's Avatar
I agree with you there at some point the po had an issue. Will probably need to put at least an engine harness in there.
Old 04-17-2016, 11:00 PM   #7
jdalexa84
I was looking at redoing my harness in and you can get most of the primary wire and the correct terminal connector for the firewall plug (part #CT712 line:Bwd) at Oreilly.
The terminals are $0.56 each
