Old 04-17-2016, 01:36 AM   #1
ebaby35
Ford 9" for 62' c10
Looking for a ford 9" and wondering does it matter what the 9" comes off of? Besides having the mounts moved 9s there anything else that wood need to be changed. My understanding which may be wrong is that certain cars/trucks had better or stronger 9" in them. I'm going to the junk yard and wanted to make sure what would fit.
ebaby35 is offline   Reply With Quote
Old 04-17-2016, 11:35 AM   #2
PGSigns
PGSigns's Avatar
Re: Ford 9" for 62' c10
There have been several threads on this and the search may help. The problem with a 9" is most of the ones with the width you need end up with an off set pinion. Then you have to deal with what bolt pattern you end up with. The stronger ones had 31 spline axles. It wont cost any less to build a 9" over a 12 bolt.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
