#1 | ||
59 viking lower fender reconstruct
started this thread to show pictures of the lower pass side fender reconstruct
. . back in the day just drill a hole ad a long bolt and fender washer call it good ....Fast foward 38 years with The help from the people here the internet almost all parts for these truck available thought I could do better . . Before ![]() . Not fnished just yet why the vicegrips . ![]() . . Quote:
Find a Viking fender because the wave in the viking fender (non Apache) to flat .... Not sure..? . this is the piece (in red ) I don't think is available.? . ![]() . ![]() . . ![]() . ![]() . ![]() . . . ![]() . . it bolt here to the cab . ![]() . . ![]() . ![]() . . AFTER . . ![]() . ![]() . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
Re: 59 viking lower fender reconstruct
the front fender lower inner brace is available for the pick ups for about $30. the cabs are the same, so the profile would be the same where the fender and the cab meet. maybe you could make one of those brackets work on the back side of your fender so you could support the fender to the cab mount area. then fab up or buy a lower rear fender patch for a pick up and use what you need to fit your fatty fenders.
the fender brace was one of the part numbers i listed from the lmc link
you doing a bang up job on the cab restoration ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#4 | |
. just want to get it by inspection & start the clock on the paper . Holy Smoky #9 . that is very cool thanks man . ![]()
The hood needs alot of love to bring it back
. . ![]() ![]() . ![]() . . I bought a spare hood that was solid but needs alot of work last yr so I could keep going little primer some semi black to stop the rust . . . . . ![]() . . . . . . Waiting for some high dollar wipers . . . . . . .
#6 | |
![]() the only arms for our trucks are total pos
it is good stuff unless you have a windshield that has a lot of pitting . Last time took a car in for an inspection... the Trooper wanted to see the wipers working ... Flashers, all ext lights working hi-lo beams the works
