K20 1978 lift questions?
Hey guys im here to ask about lifting my truck. I know there are a few out there but just thought id ask. I have a 78 k20 that im currently been restoring and just thought to do the lifting while everything is off. I have over load springs in the back currently but i was trying to figure out how much I can lift it with out haveing to start changing things like my drive axle and all that other stuff... i was thinking either 32" tires or 33" with a 2" body and 2" suspension.....thoughts? Id almost be fine doing 33" with a 2" suspension.
Re: K20 1978 lift questions?
4 inch suspension with 33s is pretty much the limit unless you want to cut up the fender wells. I did a 4 inch and 2 inch body with 35s and really regret the body lift.
I would recommend replacing the driveshafts regardless of what size you go with as they are probably worn out anyway and get longer brake soft lines. |
Forget the body lift and go with a 4" suspension lift. You need longer shocks and brake hoses and that is it. Oh, and raised steering arm. No need to replace driveshafts unless they are worn out. You can figure that out once the truck is running and driving. It's pretty rare, from my experience, for a driveshaft to be shot. As long as the yokes have been greased they should be fine. No issues with drivetrain angles on a LWB with 4" lift. Go over 4" and you get into needing to lengthen drive shafts, longer cables, pinion angles...
4" lift is plenty for most offroad situations anyway, I was really impressed how capable my k10 is with 4" lift and 33's.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Weld in frame brace at the steering box would be advisable with 33's and up.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
If you have not seen http://offroaddesign.com/ they got everything you need.
Just did a 2.5" on a 78 K20, have 33.5 inch tall tires and it's just fine ...
1985 K20 4spd 1978 K20 4spd |
on my 74K20 and my wife's 73K20 Sub, I only have add-a-leafs,and I run 33's with no problems,I put a 2.5"lift kit on my 72K20 and run 33's ...If I were you I would just go with the add-a-leafs,alot cheaper and don't have to change anything else
| Bookmarks |
