Old 09-27-2003, 12:12 PM   #1
polevault1977
Pick'n up the pieces!
polevault1977's Avatar
TV cable set-up
This may have been posted before, but I thought someone might be interested that run 700 trannys. I have installed Bowtie Overdrives TV cable set-up. Very well engineered. Here's what it looks like on a Eledbrock carb. Very clean. Alot better than the old bracket I fabbed up. Danny
polevault1977 is offline   Reply With Quote
Old 09-27-2003, 12:13 PM   #2
polevault1977
another
Old 09-27-2003, 12:42 PM   #3
67_SS396
I have the same setup and am very pleased. It's costly, but well worth it to get it right, in my opinion.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-27-2003, 12:56 PM   #4
dhenthorn
Where did you get it and How much?
dhenthorn is offline   Reply With Quote
Old 09-27-2003, 01:44 PM   #5
Slammed67
Progress = 0%
Slammed67's Avatar
I agree, WELL worth the money! I had originally installed a Lokar TV cable and the trans shifted like crap. I installed the Bowtie Overdrives set up and it was like night and day. Do you have yours set up to shift aggressively??
Bowtie Overdrives
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 09-27-2003, 03:07 PM   #6
polevault1977
109 dolarros, Bowtie Overdrives
Slammed67, I'm in the frame off process. It'll be awhile before I get to drive it and see exactly how it is set. It does move the TV spool through out it's range perfectly. I've got to started on my cab. Didn't you shave you driprails? If so any pointers. I've got started at the bottom of the pass. side. I curious about what to do with the 1/4 groove that is left right inside the door opening. Weld in a small strip or bondo? BTW, got a No Limit gas tank on the way. Frame is almost finished, later, Danny
Old 09-27-2003, 03:11 PM   #7
Slammed67
Progress = 0%
Slammed67's Avatar
No, I didn't shave my drip rails. From what I've heard, you need to cut off a few inches, weld, cut a few more, weld, etc until it's gone. Good luck with it!
