Old 04-17-2016, 03:10 PM   #1
travlinman
anyone install a double din radio Indash ?
Looking to install a double din radio in my crew cab dually has anyone here done this before? Want to install a backup camera also so I want the screen. Will I be able to fit it in a dash dezel with some trimming?
Any help or pics would be very helpful
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 04-17-2016, 06:25 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: anyone install a double din radio Indash ?
Sits too low and the screen is blocked from proper viewing by both the wheel and shifter.
I put my kenwood double DIN in my overhead console.
see link in sig below.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 04-17-2016, 07:14 PM   #3
burban nate
Think you would be better off with a flip out screen single din radio. A full size double din will not fit in the bezel, even the '89-'91 trucks only had a 1.5 din opening. If you completely remove that corner of the bezel, and fab up a new corner for the dash itself you might be able to fit it. It may take some thought to make it not look cobbied up.
Nate
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 04-18-2016, 06:07 AM   #4
travlinman
Thanks. Mine didn't come with a overhead console so I didn't really think about putting it up there. Not sure how hard it would be to add and wire everything up. I'll check your write up BLE BURBAN.
I thought about a flip out screen and thought that it would be more in the way and vibrate a ton that would probably drive me crazy.
I keep doing some research and see what I can find
65 Pontiac
69 swb-sold
71 lab sold
Old 04-19-2016, 12:26 AM   #5
UKNOWME
UKNOWME's Avatar
Custom built center console. This is the wrong year but you get my point.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 04-19-2016, 12:36 AM   #6
UKNOWME
UKNOWME's Avatar
double post
1964 Chevy c10
Old 04-19-2016, 01:33 AM   #7
andrewmp6
What about a rear view mirror with a screen in it for a back up camera ?
andrewmp6 is offline   Reply With Quote
Old 04-19-2016, 06:01 AM   #8
travlinman
Thanks guys.
Ya a rear view mirror with camera might work. Don't know how I would hide all the wiring with the mirror being a little lower on these trucks.
I did find a couple pics of thus truck that has 1 in dash. Looks like a pretty clean install.
65 Pontiac
69 swb-sold
71 lab sold
Old 04-19-2016, 06:03 AM   #9
andrewmp6
But a screen that low might be hard to see tho.
Old 04-23-2016, 06:27 PM   #10
BLE 'BURBAN
Another option is to open up the dash where the center A/C vent is at right above the ashtray and install it there.
Old 05-03-2016, 09:34 PM   #11
shootracing22
I did it. I installed a pioneer double din in the factory location in my 1989 square body crew cab Chevy it is a tight fit but worked for me. The truck came from the factory with a slightly larger radio. To make it work I ordered a radio sleeve that was specifically made for my model of the pioneer radio I had bought I placed the sleeve in the dash where I wanted by cutting on the dash with a small body saw and then using my mig welder that is set up to weld thin sheet metal I tack welded the radio sleeve in place where I wanted. The original radio was a little wider than the double din so I have 2 small gaps on the sides that are not noticeable but I plan to try trim to fit then glue a trim plate that I have from another double din radio or I can get another instrument panel from a truck that did not have the big radio mine had.
Note: Be very careful the take every precaution to prevent slag from hitting the carpet it can catch on fire quickly.
Also I think it works best with a radio that does not have a folding face. The screen will be smaller to make room for the CD slot and extra buttons but I find the buttons are easier to locate when driving. I am really happy with my double din one of the best mods I have done. I apologize that I don't have any pictures of my radio on my build page I done.
http://www.4btswaps.com/forum/showth...-for-feed-back
2006 GMC X-cab Z71 5.3LS
1994 GMC 1500 LWB 2wd
1989 Chevy Crew v3500 4x4 12 valve Cummins swap
Last edited by shootracing22; 05-03-2016 at 09:56 PM. Reason: Signature and radio info
shootracing22 is offline   Reply With Quote
Old 05-03-2016, 10:02 PM   #12
Firebirdjones
I'd do the rear view mirror setup before resorting to chopping up the dash. I've driven the rear view mirror setups, pretty nice actually and in a natural spot you would look when backing up Easy to see. Plus you get all the other cool features like outside temperature, compass, and an auto dimmer any time headlights come up behind you. I find myself putting these modern mirrors in our classic cars.
It's actually easy to hide the wiring. You could do what all the newer cars do with low mirrors and make it look factory, they have plastic channel that runs straight up to the reveal molding (how my duramax is done) or they use a simple flexible wire covering and grommet (how my sons mustang is done)
Lots of options there.
Firebirdjones is offline   Reply With Quote
