Old 04-17-2016, 07:33 PM   #1
lgehring
points to hei
Good evening gents
1966 c20 250 4spd all stock stuff. I am thinking about putting in a stock HEI distributor. Mine is pretty worn. According to the numbers by the distributor it is a 1971 engine. I have not checked the head numbers. Do I just by a HEI distributor for a 1975 engine? I use spark plugs for what year. What else do I need to know? Thanks, Lowell
lgehring is offline   Reply With Quote
Old 04-17-2016, 08:21 PM   #2
vince1
Re: points to hei
I got one from a 78 Nova 250 in a junk yard. It looks like the original cap because the electrodes in the cap are so corroded but it sure works better than the points distributor. I pulled the wire out of the ignition switch connector, put in a terminal with short piece of wire, then Teed onto the old one and ran a new one to the distributor to get the full 12 volts. Once I gave the distributor enough advance it runs and starts really good. Looked all over the junkyard for a spare module from the V8s but all had been stripped.
vince1 is offline   Reply With Quote
Old 04-17-2016, 09:35 PM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: points to hei
Here ya go:
http://www.ebay.com/itm/NEW-STRAIGHT...9TULjm&vxp=mtr
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-17-2016, 09:53 PM   #4
urmyboyblue
Re: points to hei
An option would be to replace the bushings in the distributor and replace the points with a Pertronix module. Keeps the look of the point distributor with the dependability and RPM capability of an electronic ignition. And you don't have to change plug wires.
Otherwise, I would just use an HEI that would fit a 75 model 250- including plugs and wires.
urmyboyblue is offline   Reply With Quote
Old 04-17-2016, 09:54 PM   #5
lgehring
Re: points to hei
Thanks guys!
Old 04-18-2016, 03:39 PM   #6
Rust-O-Matic
Rust-O-Matic's Avatar
Re: points to hei
Just for reference, I put an HEI distributor from a 1980 pickup with a (I presume) 250 into my '65 230. It fit perfect and worked like a champ. You can probably use just about any year in between that range.
Rust-O-Matic is offline   Reply With Quote
Old 04-18-2016, 04:00 PM   #7
Wrenchbender Ret
Re: points to hei
The 75-77 truck HEI's had an external coil. Its best to use the 78 up or car unit.
Wrenchbender Ret is offline   Reply With Quote
