Old 04-17-2016, 08:32 PM   #1
Ian71GMC
Question Door Panel Help
I bought a driver's side door that didn't have an interior panel on it, but I already had one so it wasn't a big deal. But after getting the door mounted and the panel ready to put on, I discovered the little plastic pieces that are in the door to screw the panel into are gone. I've looked around, but no one sells the little pieces themselves. What can I buy that will do the job and hold my panels in place? Any help is appreciated!
1971 GMC C2500 - 350 SB - 700R4
1972 Chevy C10 - 350 SB - TH350
Ian71GMC is offline   Reply With Quote
Old 04-17-2016, 11:08 PM   #2
68bowtie
68bowtie's Avatar
Re: Door Panel Help
1972 plastic clips or 67-71 cage nuts? i assume you mean along the bottom of the panel?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 04-17-2016, 11:12 PM   #3
Ian71GMC
It's a '72 door, so clips. And yes, along the bottom of the door
Old 04-18-2016, 12:15 AM   #4
Boyd67
Boyd67's Avatar
Re: Door Panel Help
I think you can use the square little plastic things that go in your bumper for a tag. I had to use them on my 67 because where they were suppose to be there was just a square hole. Someone had broke them out of door. You will just have to find the right size. Autozone or advance should have them.
Boyd
-67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie
Boyd67 is offline   Reply With Quote
Old 04-18-2016, 08:23 AM   #5
FlameOut
Re: Door Panel Help
These look real similar to the clips used on the 72.
Amazon.com: 25 Front Door Trim Panel Retainers... Amazon.com: 25 Front Door Trim Panel Retainers...
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 04-18-2016, 08:58 AM   #6
Boyd67
Boyd67's Avatar
Re: Door Panel Help
Car andTruck shop has them. $3 for a kit. Left side of page 2nd item from top. If that's what he is looking for.
Page 26
https://issuu.com/truckandcarshop/docs/ts_60-72_web
Boyd
Old 04-18-2016, 09:52 AM   #7
Ian71GMC
Re: Door Panel Help
Which should I use if I'm using a door panel from a '71 pickup on a '72 door? And will a '71 armrest fit on the '72 door also?
Old 04-18-2016, 10:31 AM   #8
Boyd67
Boyd67's Avatar
Re: Door Panel Help
67-71 uses basically a square nut and screws. I think you would have to drill holes in the door panel to line up with nuts. I don't know what to tell you except GOOD LUCK! And as far as the arm rest I have no clue. Sorry I can't help you any further. I didn't realize you were trying to mix the two
Boyd
Old 04-18-2016, 10:36 AM   #9
Ian71GMC
Re: Door Panel Help
Thank you for your help! I'm just trying to make my truck look a little better with the parts i have instead of having to buy new. But I appreciate any help!
Old 04-18-2016, 11:16 AM   #10
Boyd67
Boyd67's Avatar
Re: Door Panel Help
I completely understand that my man. Keep us updated on what you figure out
Boyd
Old 04-18-2016, 12:17 PM   #11
SIXTY9
Re: Door Panel Help
I put 72 interior door panels on my 69 and the armrest worked.
SIXTY9 is offline   Reply With Quote
Old 04-18-2016, 01:29 PM   #12
Ian71GMC
Re: Door Panel Help
But will a '71 armrest work on a '72 door?
Old 04-19-2016, 04:06 AM   #13
SIXTY9
Re: Door Panel Help
I pretty sure it will, you just have to add a way to put the fastners in the door to hold the door panel on. Then the armrest will fit.
Old 05-06-2016, 09:56 AM   #14
Ian71GMC
Thumbs up Re: Door Panel Help
Alright, I figured it out! At Advance Auto Parts, they sell "nylon door trim nuts" and door trim screws. I went in and explained what I needed and the manager took me right to the nuts and screws! I bought an assortment pack and smallest nut in the box did the job, but I did have to drill the holes in the door just the slightest amount, hardly noticeable. So if you are in the same predicament I was, I would recommend Advance Auto for this solution! And yes, the '71 armrest fit on my '72 door.
Old 05-06-2016, 01:30 PM   #15
midniteblues
midniteblues's Avatar
Re: Door Panel Help
72 had longer posts for the door handle and window regulator. Cause of the thicker door panels.
They will work but may stick out a Lil farther than 67-71's regulators.
Those Lil square nuts can be a pain in the but.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
