04-17-2016, 09:15 PM | #1 |
Inner door weather strip
My 50 was crashed. Have to replace the cab, and found a great 47 that is rust free.
Made the purchase and have to deal with some of the differences. One I discovered today is the difference in how the weatherstrip on the inside of the door attaches. The 47 (and 48) have a spindly tille strip that holds the weathersrtip in place. The 50 has a channel that looks like a much better attachment, and was obviously an improvement to the earlier model. Can this channel be removed and applied to the 47 cab? My guess is that it is spot welded in. |
04-17-2016, 09:41 PM | #2 |
Hollister Road Co.
Re: Inner door weather strip
they repop that channel ant it would fit 47-49
04-17-2016, 10:03 PM | #3 |
Install with screws rather than spotwelds?
04-18-2016, 12:55 PM | #4 |
If you're speaking of the channel on the cab yes it is spot welded on, I had to remove mine on my '53 when I replaced the kick panel. Just be gentle taking it off. You can also buy the channel from resto places, might be easier.
04-18-2016, 01:55 PM | #5 |
already painted my interior. I wonder if small pop rivots on the ripop channelwould give any hangups on the rubber install
04-18-2016, 02:40 PM | #6 | |
I spot welded mine by plug welding, then used a dremmel to clean up the weld flush to the bottom.
53 Chevy Pickup |
04-18-2016, 04:00 PM | #7 |
72 Mountaineer
I thought about removing the one I have from the 50 cab. Looks like might be pretty tough to get at it where it runs next to the dash. Did I you just pry it out in that area or are there no spot welds there? Last edited by Jemezcrusher; 04-18-2016 at 04:02 PM. Reason: Add name |
04-18-2016, 04:06 PM | #8 |
Jemecrusher:
This is another difference you might encounter between a 47 and a 50. Not sure when it was changed but my 47 has a single rear cab support trunion in the center with a rubber bumper in each rear corner. Apparently it was not up to snuff and GM redesigned the rear support with a single arm trunion at each corner and changed to three support braces on the cab's rear wall behind the seat. Just an observation. You will figure out what you have to do where you have both style cabs, if they are in fact different. |
04-18-2016, 04:31 PM | #9 |
Know about the mount difference. The center mount may have put too much stress on the cab so they moved to the trunion mounts. My neighbor has a 47 with a manual that refers to the "comfort ride cab"
My 235 and driving style will not impact this so think I may stick with the center mount and new bumpers. Don't think that will be a problem, and would be less work. I am missing the center mount bracket or at least there are empty bolt holes on the cab that indicate I am missing something. Will have to look at the neighbors GMC to verify. looks as if the cross members are the same so should not be a big deal Last edited by Jemezcrusher; 04-18-2016 at 04:32 PM. Reason: Spelling |
