5 lug conversion ?
Decided to go to 5 lug on my 64. I have some questions. I have 2" drop coils right now. Can I use a front disc setup from a 79 and keep my existing coils? Just order a drop spindles from a 73-87? Thanks in advance for any help
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
![]() Join Date: Jan 2011
Re: 5 lug conversion ?
All depends on what parts you decide to use from the donor. If you use the a arms you will need the drop spindles from that era. If you are going to keep you a arms order the spindles to fit them and just get the rotors, dust shields and calipers from the parts store. Lots of info in the FAQ section on this. And yes you can use your springs
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#3 | |
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
