04-18-2016, 12:27 AM | #1 |
Removing left-upper 4x4 ball joint without removing steering arm?
Doing ball joints (and bearings, and hub/spindle seals, and axle shaft seals, and on ad nauseum) on my K10. First time at this, but no problems... until I got to the last ball joint, the driver-side upper. The tool doesn't fit between the steering arm and the ball joint, so the steering arm has to come off. So far, that ain't happenin'. I have tried copious amounts of PB Blaster (otherwise known as the brain-cell killer), SeeTen's socket trick, and of course a BFH.
So I began thinking (always dangerous, I know) - work smarter, not harder. Instead of beating the crap out of the steering arm with a sledge, how else could I press out the joint? The immediate and easiest idea is to modify the receiving tube on the press to be a "C" shape, cut out where the steering arm is in the way. But that leaves me with a very expensive adapter kit that I'd prefer to return to Autozone. I wondered if any of you have ever come up with a good solution. Removing the steering arm just to press out a ball joint seems like a waste of time and energy. All you really need is some strong, U-shaped piece of metal to act as a partial receiver tube for the joint. I'll keep working on a (cheap) method, but if anyone's got an idea or done this before, say the word.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
04-18-2016, 07:24 AM | #2 |
Re: Removing left-upper 4x4 ball joint without removing steering arm?
I disconnect the tie rod so the knuckle can swing out to where I can hit it with a good swing. Those little cones will work their way up. Just have to get a better smack on it. Heat will also help
04-18-2016, 08:36 AM | #3 |
Well, unfortunately I already removed the knuckle from the truck. Didn't think about having to remove the steering arm until I went to press out the joint. Good thing is I can clamp it in my vice... the bad thing is that I can then destroy my bench hammering on the part clamped in the vice.
04-19-2016, 08:55 PM | #4 |
Well, I did it. For anyone searching for this same thing in the future: Go to the hardware store, and buy a 2" galvanized pipe nipple 3-4" long. Four bucks and that's all you need, and it is the right inner diameter to accept the ball joint. Put the nipple in the vice, take a hacksaw to it, ending up with a "C" shape. Mark it first so you take off only what's needed where the steering arm is too close to the joint to fit a tool. Then use the new C you just made with a press and presto! Super easy, way easier than fighting with the steering arm. Hope this helps someone later!
09-13-2024, 03:55 PM | #5 | |
With inflation the 2" x 4" nipple costs me $6.98, almost double what you paid 8 years ago. Worth every penny. I used a cut off wheel to make the cuts needed.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke Lariat 2007 BMW X3 2023 BMW X3 M-Sport 2020 BMW 540xi M-Sport 1995 Harley FLSTC Last edited by ohboy321; 09-13-2024 at 05:03 PM. |
09-14-2024, 07:13 AM | #6 |
I recently did this job on my 1970 Blazer, and rented the Autozone ball joint tool. I was able to remove and replace the LH upper ball joint without removing the arm, damage to the tool, or resorting to making tools. I don't remember any drama. The knuckle was a dry Arizona part, so it came apart super easy. I used NOS GM ball joints, and it went back together effortlessly.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
09-16-2024, 10:30 AM | #7 | |
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
