04-18-2016, 10:10 AM | #1 |
Hit the scales! What do they weigh?
I was out cruising and decided to pull in the local grain elevator and weigh my 1 ton C30 panel truck. She weighed in at 4,860 lbs with about 50ish pounds of extras in it.
I didn't think that was too hateful considering how big it is. I'm running a tbi 350/4l80e combo. Also have metal floors compared to the original wood rear flooring. Anyone else weigh their truck?
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 |
04-18-2016, 12:15 PM | #2 |
Re: Hit the scales! What do they weigh?
had to weigh my '65 Chevy C20 for CA registration
hit 4280lbs empty and only 1/2 tank of fuel.. severe rust and missing bed boards probably saved me a hundred lbs |
04-18-2016, 01:46 PM | #3 |
I have a 65 C10 SWB stepside with a BBC and roll cage. Weighed in with me in it at 4000# almost dead on. Without me, probably 3700#.
04-18-2016, 02:42 PM | #4 |
Moderator
Our trucks are really light for their size. I got the original weight numbers from GM Heritage when I was importing my truck and registering it.
04-18-2016, 06:20 PM | #5 |
Oh the memories!! CAT Scales. I used to have a collection of about 550+ of those "Super Trucks" cards. I think I averaged about 3 cards a week for a few years back in the 90's.
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue. http://67-72chevytrucks.com/vboard/s...d.php?t=523009 |
04-19-2016, 01:58 AM | #6 |
'63 short-wide 454 - 4,000 lbs dead, with driver.
1963 C10 short-wide Turbocharged 454, T56, 4.11 posi http://67-72chevytrucks.com/vboard/s...d.php?t=605408 1963 C10 suburban Unknown, unknown, 3.73 open http://67-72chevytrucks.com/vboard/s...d.php?t=622037 |
04-19-2016, 01:35 PM | #7 |
I'll have to weigh my Suburban. I know its heavy as I had to push it for about a block a week and a half ago.
04-20-2016, 12:14 AM | #8 |
Had to weigh mine for registration too. Little over 5,700 eight years ago. I think she's getting heavier with age too... like me!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-20-2016, 12:22 AM | #9 |
meowMEOWmeowMEOW
I think its funny how much these weights can vary. You 4x4 and c20+ guys weighing in at 2.5 tons or more, yet there are a few of us in the 31-3700 range (a few even less).
My 66 with an Lq4, no inner fenders, aluminum front wheels, full audio custom interior, fuel cell etc should be around 3850 (unverified for a few more weeks at least).
04-20-2016, 10:57 AM | #10 |
4600 lbs empty on a scale at the gravel place.
66 Custom Camper 327/ 4 spd. Bone Stock, down to the split rims |
04-20-2016, 11:52 AM | #11 |
Hey guys put the year and type truck you have please .....
63 C20 long fleet 327 4SPD 750-17 ALL stock 4200LBS |
04-21-2016, 10:39 PM | #12 |
Mine is a 65 short box step side. 350, aluminum heads/manifold, 700r4 and I weighed 3675 without me in it, and full of fuel
Posted via Mobile Device |
04-27-2016, 05:22 PM | #13 |
66 8' fleetside I-6 4sp manual 1800 kg with me and 1/2 tank. 1700 kg would be about 3750 lbs.
07-04-2018, 12:52 AM | #14 |
But Found Her 25yrs Later!
Bump
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-04-2018, 10:28 PM | #15 |
3914 lbs with my weight subtracted and 1/3 tank fuel. I don't know where I got the previous figure from but it is a little low. This one was metric tare at the dump and I used a metric converter.
07-05-2018, 10:24 AM | #16 |
65 Short Fleet BBW with a small block, iron Heads and , Turbo 400, 1/2 tank of fuel, no driver. 3720
07-05-2018, 06:11 PM | #17 |
1969 GMC "Longhorn" type. 4,680
That was 20+ years ago. Now when I weigh-back at the dump it reads ~5,300 with tools etc. -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
07-15-2018, 08:53 AM | #18 |
`64 shorted alum diamond plate (no wood), 350/350, PS, PB, spare tire, 1/2 tank gas 3,880 lbs
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
09-03-2018, 12:55 AM | #19 |
65 short stepside on a 62 frame and steel diamond plate in bed.. 283 & TH350 with about 1/4 tank of gas = 3780# (without me)
