LMC Gast Tank Question
Recently purchased an LMC top fill under the bed gas tank. It came with 2 bolts/nuts and also 2 bolts that are L shaped on the end. Anyone know why these are L shaped and also any special way im suppose to use these? Thanks.
Also, title should say "Gas" not "Gast"! |
Its a Truck Thing......
Re: LMC Gast Tank Question
The L shaped ones go into the frame.
Some folks can post a pic to show you how they run, if not I can do it later today. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
#3 | |
The two bolts are used for the straps on one side, and the l-shaped grabs the straps on the other side and allows you to tighten or loosen the straps.
1972 Chevy C10 Shortbed/Wood Starting LS1 GTO Swap |
Ok thanks for the replys guys. 71meangreenc10, if you don't mind posting a picture later Id like to make sure im installing it correctly. Thanks!
#5 | |
Smitty
#7 | |
67 C10 SWB Chevy |
#8 | |
That's why we are here to help out. Smitty
