04-18-2016, 11:46 AM | #1 |
Installing my Western Chassis drop
Man I'm getting old, I only finished on side yesterday. I only worked about 4 hours on the project. I started on the left front, replacing the spindled, spring,shock, both ball joints, and swap bar bushings. And a bunch of cleaning.
The tear down was easy, I have to brag again on southern trucks. Everything unbolted, cotter pins pulled out easy. But all the years of rode dirt,tar,sand and whatever. Made for some tuff and very dirty cleaning of the A-arms, and surrounding areas. The only thing that kicked my butt was the lower ball joint. Which is a press in or beat in joint. The joint was larger than the A-frame hole. So after some cleaning and running a die grinder with a flat bit around the ID of the ball joint hole. And hit the belt sander with the ball joint its self. I was able to get it started and pushed in to place. I'm sure the right side will go much smoother. Then onto the rear for the leaf spring hangers. The shackels are already installed. And removing the over load spring. Then installing the transmission and new intake manifold. I may get to drive this truck one day. Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
04-18-2016, 06:44 PM | #2 |
Re: Installing my Western Chassis drop
Nice progress!
I am in the opposite order you are... I have the trans scheduled late this week, then the suspension, wheels and tires... Been a long wait to get started but finally, I am!
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
04-19-2016, 03:20 PM | #3 |
driving is in my blood
The fact you ground down a press in ball joint to make it fit without pressing so hard scares the crap out of me.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
04-19-2016, 11:26 PM | #4 | |
30 years of years and road crud built up there. There was no way the ball joint was going in to that hole. Looking back over my years turning a wrench, I bet I have installed a couple hundred sets of ball joints without any issue's. I have always cleaned and prep the holes for the new joint. It still was a tight fit, groaned all the way in. Using a ball press. The side I did today wasn't as tough. Front end is back together. And trans is setting on the jack ready to go back in. Weather been really nice, I think a may go riding and work on the truck Thursday. Ken
04-20-2016, 07:21 AM | #5 |
In Tom's defense, you did make it sound like you enlarged the hole in the arm/reduced the O.D. of the balljoint which, is not good practice at all.
A good cleanup of the area however, is doing the job right. |
04-20-2016, 01:49 PM | #6 |
Exactly.
