Old 04-18-2016, 03:48 PM   #1
OUbesto
OUbesto's Avatar
Removing ashtray
Guys,
I'm hoping someone has a solution to remove the ashtray on my '70 C-10. Ashtray slides in/out easily but I want to remove it to clean it. For some odd reason it will not come out of the dashboard. I push down on the metal tab (located in the center rear of the ashtray bin just below the edge on the dash plate) almost to the point I'm afraid its going to break off but it still won't allow it to be removed. Is there something I'm not doing correctly????? Help!
1970 C-10 CST, LWB, 402/400, A/C
OUbesto is offline   Reply With Quote
Old 04-18-2016, 05:04 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Removing ashtray
pull harder
Willie Makeit is offline   Reply With Quote
Old 04-18-2016, 05:08 PM   #3
OUbesto
OUbesto's Avatar
Seriously? So you think its just stuck? It is a little rusty. I had to shoot a tiny bit of WD40 along the glides to get it to slide in/out easier.
Old 04-18-2016, 05:10 PM   #4
cdowns
cdowns's Avatar
you push down on the center thing that is there for you to put the butt in
if you push it down then pull it out
Old 04-18-2016, 05:13 PM   #5
OUbesto
OUbesto's Avatar
Ok guys I"ll give it a big, hard pull on Friday when I'll be working on it next....I'll report back!!!
Old 04-18-2016, 05:19 PM   #6
projectking
projectking's Avatar
Mine was stuck and I pulled it harder, popped right out.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 04-18-2016, 05:40 PM   #7
68panelman
68panelman's Avatar
You probly have the ball bearing type, these can get alittle stuck if not used occasionally. Maybe a little white lithium before you put it back.
68panelman is offline   Reply With Quote
Old 04-18-2016, 05:43 PM   #8
OUbesto
OUbesto's Avatar
Yup, ball bearing type.
Old 04-18-2016, 11:53 PM   #9
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Yes, push down on the center thing and pull it out.........Ha!
You may have some rust on the tracks I suppose. WD in the RIGHT places should cure that.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-19-2016, 12:13 AM   #10
geunther
geunther's Avatar
are we having a discussion on removing an ashtray?
geunther is offline   Reply With Quote
Old 04-19-2016, 12:21 AM   #11
88Stanger
88Stanger's Avatar
mine was tough too, just put the wd to it, push tab down and kinda jerk it out.
88Stanger is offline   Reply With Quote
Old 04-19-2016, 12:51 AM   #12
toolboxchev
Yup! It was a bad design, only comes out normally about a 1/3 of the way during normal use.
Think it changed in 72? Maybe?
toolboxchev is offline   Reply With Quote
Old 04-19-2016, 01:14 AM   #13
El Dorado Jim
Ha Ha that's funny right there!
El Dorado Jim is offline   Reply With Quote
Old 04-19-2016, 02:42 AM   #14
Custom/20
Custom/20's Avatar
Just make sure that there isn't anything in the tray that could bend anything on the way out. After that just press the tab down and yank real good. I recently cleaned a bunch of goo and crap out of mine. Never used in 13 years and it slid out very easily. It's not plastic so you can't break it.
Custom/20 is offline   Reply With Quote
Old 04-22-2016, 01:26 AM   #15
71CHEVYSHORTBED402
Only thing that could go wrong is the top bracket has no screws, and the bottom has one screw inserted from the top, the other from the bottom............Like how I found mine before I removed it.
Tony
Old 04-22-2016, 11:51 AM   #16
DBK81
DBK81's Avatar
So inquiring minds need to know, did you give it the big yank? Did it come out?
Am I the only one who reads these and then wishes I was in the garage with the posters helping them work on thier trucks?
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 04-22-2016, 12:07 PM   #17
OUbesto
OUbesto's Avatar
Success! I gave it a couple shots of wd40 last weekend and left it until today. I gave it one good yank and out it came. Thanks to all input. I really appreciate it.
Old 04-22-2016, 12:10 PM   #18
DBK81
DBK81's Avatar
Well now I can sleep tonight knowing that this issue is taken care of, lol. Glad you got it sorted, I know it's always unerving pulling on things if you aren't 100% sure it should come out.
