04-18-2016, 06:28 PM | #1 |
250 I6 Overheating
I plan on swapping out my son's 250 for a sbc asap.
In the meantime, I have to keep this I6 on the road for a while. It's a 250 I6: It doesn't overheat at idle, it only overheats while driving. This leads me to believe it is a cooling issue and not an air flow issue. Even though air flow isn't the issue, I'm switching it over to a 3000cfm electric fan. I've already changed out the thermostat. The old one was a 160, the new one is a 180. This didn't help at all. While driving the engine heats up to 250 degrees. Obviously, I shut it down as soon as it gets this hot. There is no leaking of coolant at all. No hoses are collapsing. I've double checked the gauge, it works perfectly. It has a brand new 3 core radiator. This is the first time that we've had this motor running, I have no idea of its previous history. Worse case scenario is a blown head gasket. A buddy told me to take off the radiator cap rev the engine to 2000RPM and watch inside the radiator as the engine heats up and look for 'bubbles'. He said if I see bubbles it has a blown head gasket. No bubbles at all. Anyone else have any methods for checking for a blown head gasket? I'm aware of a few issues that I plan to work on that may be causing the coolant flow issue: Timing(if it's a timing issue should I advance or retard the timing?) Water Pump(any suggestions on how to check this?) I'm going to flush and burp the system Are there any other issues that I'm not aware of that may be causing the coolant flow problem? Thank you Last edited by '63MurderTruck; 04-18-2016 at 06:34 PM. |
04-18-2016, 07:38 PM | #2 | |
Re: 250 I6 Overheating
You never know, that could be why yours is over heating because of the pump, I know it made a big difference for me. |
04-18-2016, 08:29 PM | #3 |
What % are u running?
Where are you located? Is the electric fan in front pushing or behind pulling air thru radiator? Rotating correct way? You have electric or mech gauge? Mech hooked on head above intake between #2-#3? What's your oil level, temp, pressure looking like? Does your heater even get hot? I've got 250..stock fan and an aluminum radiator that is in my opinion too small..my mech gauge runs at about 200 but flexes between 210-215 and 190 normal and 200 highway 33%antifreeze probably but can go low as 10-25% as I'm in new Orleans (not cold) Overheated once.. Realized PO had taken thermostat out.. Think I've used my electric fan (in front pushing) twice but really didn't need it That's in town in new Orleans in traffic And my rings are bad and 2 weeks ago was running on only 5 cylinders.. Ur water pump moving? Do y you have OG fan as well? |
04-18-2016, 09:12 PM | #4 |
Making sure the water pump was creating enough flow and/or coolant passages not plugged would seem the most obvious to me as well. Are you getting heat from the heater core?
04-18-2016, 09:49 PM | #5 |
bottom rad hose collapsing?
ron |
04-18-2016, 09:55 PM | #6 |
what anti freeze mixture are you using? how many lb pressure cap are you using?
what does your guage read to and when it read 250 degrees is it boiling over? ron |
04-18-2016, 10:44 PM | #7 |
Never Ending Projects
Where is your temp sensor? If in the head, you're likely getting a false reading. I had this issue on my wagon. Moved to port under the t-stat housing and temps were back to normal.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
04-18-2016, 11:22 PM | #8 |
i am having this current issue. i ordered a new t-stat housing from rock auto for 6 bucks + shipping.
04-19-2016, 12:25 AM | #9 | |
ron also these vehicles did not use sensors but sending units. sensors came in with the use of computer operated systems Last edited by padresag; 04-19-2016 at 02:58 AM. |
04-19-2016, 02:45 AM | #10 |
Like as has been suggested, bottom radiator hose collapsing? If there is no spring in there it will probably collapse. After you stop to look at it all seems normal.
Water pump impeller OK? On another car brand I found the impeller in pieces in the bottom rad hose. I just remembered to remove the cardboard from the front of the rad and am surprised it didn't over heat. |
04-19-2016, 10:30 AM | #11 | |
As noted above, it can also be the lower hose collapsing at speed. BTW, my phone autocorrected sender to sensor.
04-19-2016, 11:12 AM | #12 | |
more and more we are being managed by devices that only respond to the current info these trucks were originally designed with a 7lb cap and a 50/50 ratio water/ethylene glycol mixture to give it a boiling point of 251 degrees and with a 13 lb cap and 50/50 that boiling point goes to 269 degrees as long as the coo;ing system is operating a normally In actual fact the only time that 160-180 degrees means normal operating temp is when it is running straight water and and no pressure cap as the boiling point of water ie then 212 degrees. one can run at 230-240 degrees and be within normal operating temps with the right mixture and pressure cap. for every lb of pressure it raises the boiling point 3 degrees. if one is using an idiot light or a dash guage that reads normal nobody is concerned, but if they have a guage that is reading 220/230/240 they get nervous but the above criteria adjusts for that. one just has to remove that 212 degree boiling point from their mind when the system is under pressure and anti freeze. ron Last edited by padresag; 04-19-2016 at 11:17 AM. |
04-19-2016, 12:30 PM | #13 |
[QUOTE=padresag;7565890]analogue or android phone?
more and more we are being managed by devices that only respond to the current info these trucks were originally designed with a 7lb cap and a 50/50 ratio water/ethylene glycol mixture to give it a boiling point of 251 degrees and with a 13 lb cap and 50/50 that boiling point goes to 269 degrees as long as the coo;ing system is operating a normally In actual fact the only time that 160-180 degrees means normal operating temp is when it is running straight water and and no pressure cap as the boiling point of water ie then 212 degrees. one can run at 230-240 degrees and be within normal operating temps with the right mixture and pressure cap. for every lb of pressure it raises the boiling point 3 degrees. if one is using an idiot light or a dash guage that reads normal nobody is concerned, but if they have a guage that is reading 220/230/240 they get nervous but the above criteria adjusts for that. one just has to remove that 212 degree boiling point from their mind when the system is under pressure and anti freeze. ron[/QUOTE Very well said! Isn't that also why most cars now in days run hotter? One of the old work trucks I used to ride around in ran at 220 all day and never had a heating issue. Ran great and it was a 1997 GMC. |
04-22-2016, 02:35 PM | #14 |
25/75% anti/water mixture
16lb cap Small aluminum radiator (1-2pass) 5 leaking rings Trail of 20/50 oil smoke Mech gauge at OG temp location on the head Stock 4 blade metal fan (Have auxillary fan but never turn it on) 195-200* Goes up to 230 sometimes but sweeps quickly back to 195*ish That's in new Orleans and in stopped traffic Thundering 60-65mph highway still stays about 200* |
04-22-2016, 04:34 PM | #15 |
It's probably not a problem with the Chev I-6 but with the AMC 232/258/4.0L there is the possibility of getting a water pump that turns backwards if the belt set ups are not correct. Serpentine vs V belt and such. And the old plastic impellers break.
