Old 04-18-2016, 09:06 PM   #1
Original60Apache
Original60Apache's Avatar
1960 Chevrolet pickup clutch return
So for some reason my clutch pedal won't fully return to the upright position. It's been fine all this time but last night I was coming home and a couple blocks before I got home, I noticed it doesn't want to fully return. It does seem to fully disengage the clutch. It is a hydraulic clutch pickup (60-62). I am almost thinking that mypiston in the master cylinder is what is causing it like it doesn't want to push the pedal linkage to a fully returned position. Please let me know if you have any ideas.
Nate
Original60Apache is offline   Reply With Quote
Old 04-19-2016, 12:28 AM   #2
62stepside longbox
62stepside longbox's Avatar
Re: 1960 Chevrolet pickup clutch return
I had this exact problem with my 62. It turns out it was the slave cylinder leaking. I would check the master cylinder, slave cylinder and lines for any leaks.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-19-2016, 12:44 AM   #3
Original60Apache
Sounds great! Thank you so much! I'll take a lok tomorrow.
Nate
